View Poll Results: Please help name this glider
Hellferstout 5 26.32%
Numeric 9 47.37%
Knaughty 5 26.32%
Voters: 19. You may not vote on this poll
Feb 04, 2015, 03:23 AM
harborflyer's Avatar
Re__sub
Ross
Feb 07, 2015, 12:10 PM
windyhill
skybench sky bird cg question
How many guys out there balance your skybird on the back spar (rear wing tube) Ray says in the plans to balance on the back spar, does he mean the rear tube or the front tube if you have an electric with one tube ???????
Feb 08, 2015, 12:01 PM
After a small delay got the tail feathers done and installed, just need to put the little triangle stock reinforcements on.
Then radio installation and balancing and getting this girl in the air.
Feb 09, 2015, 05:05 PM
Hot Dawg Glider Pilot
schrederman's Avatar
So........ How many that frequent this thread will be at SWC and F3J in the Desert? This is a real hoot and a great place to learn new skills, and polish up on old ones. Every day is flying and every night is Saturday night.
Feb 09, 2015, 06:28 PM
Balance on back of the spar, the wing rod is always placed in the main spar...
Ray
Woodys Forever
Sky Bench
Feb 09, 2015, 09:58 PM
Mine is balanced at the rear edge of the spar
Flies Great
Modified with all flying stab
Feb 10, 2015, 11:11 AM
And when Spiker says it flies great, that's because he collects a trophy every year flying his Sky Bird in the RES AMA Nationals. I think he has a patent on the above photo of him, his Sky Bird and a Nats Trophy, I have seen similar photos many times.
Ray
Woodys Forever
Sky Bench
Feb 11, 2015, 04:57 AM
windyhill
cg. ?
Then you mean 4 1\4 inches from the leading edge. ?
Feb 11, 2015, 06:21 AM
The rear edge of the main spar.
Ray
Woodys Forever
Sky Bench
Feb 11, 2015, 09:48 AM
windyhill
got it, that is where I had it in the beginning.
Feb 13, 2015, 11:23 PM
life long racing nut & modeler
granada don's Avatar
Hot Damm we have some wood to show, after machining alum for about a year making the three engines now I can look at some wood
Ray has the first test hull starting to take shape
The boat is being built up-side down, then the fixture legs will be reversed and the deck can be put together
The building fixture is in two parts so it can be taken apart inside the hull and removed
We are building a test boat first to make sure it all works OK, as there will no skin on this one just the frame stuff so we can mount the engine etc
G Don
Feb 14, 2015, 02:24 AM
who has rabbit ears down
Captain Canardly's Avatar
That's lookin' gorgeous -and strong!
Feb 14, 2015, 10:23 PM
Hi John
The frames are 1/4" thick, most likely it will weigh about 20 lbs or so as it will be all hardwood and it will add up
Plus all the alum in the engine - steering etc
G Don
Feb 19, 2015, 10:00 PM
Egads! It's a GIRL!
Lil Stinkpot's Avatar
Awww, come on, guys. It's been five days since a post. Whaddup with that?
HELP ME!!!< I think I'm getting addicted to cutting foam!!! slowflyer Foamies (Kits) 7 Feb 21, 2011 01:58 PM
I'm Getting my FiXX Craig558 Foamies (Kits) 6 Mar 18, 2002 11:40 PM
looks like i'm getting a piccolo, any advice? cheapflyr Electric Heli Talk 13 May 10, 2001 08:34 AM
I'm getting worried SchiessCo Electric Plane Talk 1 Apr 21, 2001 08:11 AM
