Feb 14, 2014, 09:03 PM
Phantom Mechanic
PhantomII's Avatar
I would love to build this plane but I would like to make it about 24 inch wing span
Feb 14, 2014, 09:08 PM
Flying Half Pound and Down
DaOldGuy's Avatar
Many people have done just that.... it is a little easier to sort the CG but they power system and servo change a little.
Feb 14, 2014, 09:12 PM
Phantom Mechanic
PhantomII's Avatar
I just need to find a way to up size the plans.....
Feb 14, 2014, 09:31 PM
DaOldGuy's Avatar
Let me look around, I might have that... this plan set is tricky since the sheet are separate.
Feb 14, 2014, 09:37 PM
Phantom Mechanic
PhantomII's Avatar
Cool.....thanks
Feb 14, 2014, 09:53 PM
DaOldGuy's Avatar
Ok... I could not find any so I converted the 5mm plans from the 1st post on this thread. Since this was not a single sheet plan, I convert each of the 5 sheet singularly at 1.33 scale to get the wing to 12 inch a half for 24. Attached are the single page and tiled pages. I have never scales plans like the <multi page> so double check everything 3 times before cutting foam.
Feb 14, 2014, 11:12 PM
Phantom Mechanic
PhantomII's Avatar
Cool those ar awesome! Thank you
Feb 14, 2014, 11:14 PM
DaOldGuy's Avatar
No problem... I have been wanting to do a 26-27 range, just have not had enough time / verses all the plane projects that are already going.
Mar 10, 2014, 05:08 PM
melancor's Avatar
I only came back for the wheel pants plans, but I can't help but post again - what a great plane. How nicely it scales, hm?
May 18, 2014, 02:01 AM
Wabi-Sabi
coriolan's Avatar
Originally Posted by Ernesto Fly
This is the first flight, I will make more videos soon
http://www.youtube.com/watch?v=uCD14...ature=youtu.be
Just found your post while researching the "Cassut" on RCG, impressive flight for such a small plane:
https://www.rcgroups.com/forums/show...&postcount=751
Built one a few years ago based on this thread but 20" span balsa build:
https://www.rcgroups.com/forums/show...ghlight=cassut
Now I want to try a smaller one like your!
Jun 25, 2014, 06:04 AM
Hi colorian,
I advise you to enlarge wingspan at 15” because it's stall to easily..Good luck
Oct 26, 2017, 02:20 PM
cpaine's Avatar
I love F1's
Just started building one of these. I have 1700kv motor, should be ok.
i think mine will be modeled after the Scarlett Screamer... Not sure if i will model the new wing or keep it "hershy bar" shape....
anyone have a CG??
Oct 30, 2017, 05:39 AM
DaOldGuy's Avatar
Build recommends 40 mm from the Leading edge. It is very sensitive and due to the size, hardware placement is important. There is not a lot of room for adjusting things. 1700 kV may give you a bit of prop clearance issues.
Build Log “BigNasty” Full fuse, full wing. Free Plans and Build Guide. WaterDog Foamies (Scratchbuilt) 978 Jul 04, 2018 05:50 PM
Mini Majestic Free Plans awood12345 3D Flying 27 Jun 12, 2008 01:27 PM
“BigNasty” Full fuse, full wing. Free Plans and Build Guide. WaterDog 3D Flying 7 Jan 12, 2008 03:42 PM
No semi-scale EPP modern sailplanes? TheDudeVT Scale Sailplanes 16 Jul 01, 2005 09:47 PM
whair can I get free plans to build foam RC plane??? Aksel89 Parkflyers 4 Jul 09, 2004 03:07 AM
