Help!
New Wing Suggestions For A Slow Stick Fuselage
This could fit in several different forums so I thought this one might be the best.
I have a Slow Stick and have been following the various SS threads. I got the SS for general putting around and maybe as an AP platform. The problem I have is the SS doesn't like the wind with the stock wing and it blows here most everyday at least 5-10mph which makes the stock wing useless. So what I am looking for are some suggestions for a new wing that can handle the wind better. I am an experienced builder and have all the shop toys for scratchbuilding balsa, fan fold foam or hotwiring wing cores. I need some suggestions or links for a new wing be it whatever material. I am aware of the offerings of Steelhead and Stevens Aero and the SSX but looking to see what I could do from scratch. I have a bunch of old plans from some balsa trainers I could probably use but wanted to see what youse guys might suggest. Rick Edited: I am not ruling out any other kit wings or built wings. Any suggestions are appreciated.
Try a WingDragon wing. Semi-symetrical layout. Fits right on SS fuse by bringing the wing mounts closer together . Great windy day setup and for AP duties. Good wind penatration but still retains the SS's floaty'ness .
woops...you wanted to scratch build a wing?!! Perhaps you could hot wire some foam like Steelheads wings or fab a built up wing using foam sandwiching techniques . Spar |
Maybe I need to edit my posting. I am not ruling out any "store bought" wing kits or molded. Doesn't the WD have two different wings, maybe one with ailerons and one without? BTW I already have an Easy Star so I would be looking for something with flying characteristics a bit different. |
The Magpie Sport wing works well in a breeze on my homemade "Magstick"
https://www.rcgroups.com/forums/show...42&postcount=1 |
Just tape some Blucore, or something similar, on the bottom of the stock wing. Makes a great wind penetrating wing. Quick, simple, and if you don't like it, just take it off.
Bill |
I think you should just start cutting some odd wings and see what they do. Whatever happens will be fun and exciting. Try everything you can think of. 3D style wing, sailing wing, Delta/jet style. May have to consider different power plants though.
I'm currently experimenting on a SS stock wing trying different things. If it never works the way I want I can replace the wing pretty cheap and start again. https://www.rcgroups.com/forums/showthread.php?t=837645 |
Thanks Bill |
| Similar Threads | |||||
| Category | Thread | Thread Starter | Forum | Replies | Last Post |
| new wing for a slow stick? | ChodeMan | Foamies (Kits) | 11 | Feb 11, 2008 04:32 AM | |
| Are there any plans for a Slow Stick fuselage | sgil2001 | Foamies (Kits) | 6 | Jun 13, 2005 02:23 AM | |
| Trying new wing design for Slow Stick | sirdirk007 | Parkflyers | 2 | Jan 10, 2005 01:33 PM | |
| [B]New symmetrical wing for the Slow Stick[/B] | Perflight | Parkflyers | 7 | Nov 11, 2004 07:27 PM | |
| Best pack for stock Slow Stick/new motor? | richphoto | Batteries and Chargers | 4 | May 03, 2003 04:27 AM | |
