This thread is privately moderated by Jack Crossfire, who may elect to delete unwanted replies.
Apr 10, 2008, 03:23 AM
Jack Crossfire's Avatar
1 commute & counting
Well, the $190 beast arrived, but building the SDK is now a several commute affair instead of a few hours. In the mean time,
Code:
[email protected]:~$ df
Filesystem           1k-blocks      Used Available Use% Mounted on
/dev/mtdblock1           31488     10324     21164  33% /
/dev/mtdblock1           31488     10324     21164  33% /dev/.static/dev
tmpfs                     2048        24      2024   1% /dev
tmpfs                    63952        56     63896   0% /var/volatile
tmpfs                    63952         0     63952   0% /media/ram
[email protected]:~$ free
              total         used         free       shared      buffers
  Mem:       127908        15456       112452            0            0
 Swap:            0            0            0
Total:       127908        15456       112452
[email protected]:~$ cat /proc/cpuinfo
Processor       : XScale-PXA270 rev 7 (v5l)
BogoMIPS        : 622.59
Features        : swp half thumb fastmult edsp iwmmxt
CPU implementer : 0x69
CPU architecture: 5TE
CPU variant     : 0x0
CPU part        : 0x411
CPU revision    : 7
With the Gumstix, here are some of the tougher workarounds in addition to tracking down the dependancies:
unset LD_LIBRARY_PATH
Make sure . isn't in PATH
Edit
tmp/work/armv5te-angstrom-linux-gnueabi/binutils-cross-2.18-r1/binutils-2.18/gas/as.c
add 2 more options to the parse_args std_shortops array
'Q', 'y',
add 2 more cases to the parse_args switch statement:
case 'Q':
break;
case 'y':
break;
Then, simply go to
tmp/work/armv5te-angstrom-linux-gnueabi/binutils-cross-2.18-r1/binutils-2.18/build.x86_64-linux.arm-angstrom-linux-gnueabi
and run make;make install
Then back to the usual build script.
If U crunch 3k aerial video from VicaCopter, U probably use a 64 bit computer. Download & compile libidn. Put the .so & .a files in /usr/lib to replace the 32 bit versions with 64 bit. Back up the 32 bit versions.
Apr 10, 2008, 01:37 PM
Peace
tioli's Avatar
I'm lost, what's the 190.00 SDK again? I guess i should go back through your posts, but I'm too damn lazy.
