video evidenceQuote:
I also tried a straightforward 1C charge with a PB 12Volt battery, an 8S LiFePO4, a 4S 3200 Lipo and a 6s LiPo pack...same result on all of them except that when disconnected, the screen showed "done " and the voltage out climbed to around 24V. It also begs the question why have a screen display that says "connection breakdown"? - when exactly is this message supposed to be activated ? I would have expected it in exactly these cases |
Reason: video now removed
I can't view your video, blocked at work, but I think my charger exhibits the same characteristics. If you disconnect the main leads during charging, there is no connection error, just a rising voltage indication. I have always just pulled the balance plug to initiate the connection error. Haven't tried to see if it does it in another mode besides balance mode.
I put my upgrader kit together last night. Got all frustrated asI had some Device not found errors. I let it go, because it was getting late (12:30pm). I took some pics and reviewed them today, I realised I was plugging the adaptor in backwards. Stupid late night mistake.. I will be re-trying it maybe tonight if timing permits. Luke |
Sorry to say that we can open your video , how about send it directly into my Email box:harrif111@hotmail.com. We will take this problem seriously and will give you a answer as soon as possible. "connection breakdown" will be triggered if the charger detects that the input current falls to zero. Best regards, Junsi |
Thanks for your Wishlist ! 1)Dataloging via USB/SD Card We plan to develop the next charger which support dataloging via USB . 2)Bidirectional PC Communication for charging parameters/monitoring We will take this into consideration, now, we are study the "Logview" to see whether its suitable for our charger . 3)Bigger discharge power (~75w maybe) When we expand the discharge power to 75W, then the charger will become very hot during discharge, then it’s necessary to mount an external electrical load, such as a electrical resistance wire or a bulb, to eliminate heat. 4) Detachable input cable (no dangling cable outside) Ok! 5) Larger LCD Display (like in Tahmazo T30) We will take it into consideration. 6) Battery resistance measurement(is this possible with 106b/1010b?) We will test in our factory, and give you a answer after we finish the test! 7) 300w Charging power. We will expand our next charger’s maximum power to 300W. Thank you very much! We do appreciate your wish list! Best regards, Junsi |
HelloQuote:
It’s a good idea. Sorry to say that the balancer we currently used for 106B/1010B can’t give accurate discharged capacity for each cell, so it’s difficult to show each cell’s charged capacity . We will take this into consideration for our later chargers! Best regards, Junsi |
T |
It is very difficult to remove the cable that connects the adapter board to the charger from either the charger or the adapter board. Since I transport my charger I often have to remove that cable and I have to use tools to do it in order to prevent placing undue strain on the wires/pins. The Hyp/PQ style connector has lower insertion/removal force by design since it has a retaining clip to ensure the cable does not fall out of the connector (which is why JST-XH are so tight). The plug body is deeper and provides enough meat to grasp in your fingers so that you don't pull on the wires. JST-XH were never really intended for multiple insertion/removal cycles and are not well suited to that role. The small pin-count connectors are less of an issue since the forces are smaller. As the pin-count goes up the problem gets worse and worse. The Hyp/PQ connector is a superior design for this kind of application. It requires a minor PCB design change and an alteration to the cutout in the end plate. You will find most other good quality chargers use this style of connector for this purpose. BTW - Additional adapter boards for Hyp/PQ and TP/FP for both 106B and 1010B are available from www.eheli.com.au |
@kgfly:
That makes it another story There wasn't any hint of that in your post (#1343), so I mistakenly took it for yet another "it doesn't have my connector"-post. Sorry about that. I agree that the JST-XH are hard grip, so a larger connector would be nice. I often resolve to pulling on the leads too. That said, I haven't had one break on me yet. Easy does it I don't have a preference either way - so PQ or TP are fine with me. Often need additional pigtails for my batteries anyway. Thomas |
Thread Tools | |
Similar Threads | |||||
Best charger/discharger $ can buy | namancio | Batteries and Chargers | 30 | Jan 31, 2010 03:52 PM | |
Power Pacer Battery charger/discharger | ACE_McCOOL | Batteries and Chargers | 4 | Oct 22, 2002 12:39 PM | |
NIB Hitec CG-325 Charger/Discharger/Cycler for 4-9 cells - $39! | Jason M | Aircraft - Electric - Airplanes (FS/W) | 0 | Oct 03, 2002 03:29 AM | |
WTB Good charger/discharger 10 + cells | WickedFunRC | Aircraft - Electric - Airplanes (FS/W) | 0 | Sep 05, 2002 08:55 PM |
