Mar 01, 2012, 04:32 PM
earlwb's Avatar
Originally Posted by magrinsi View Post
I have used 19v input voltage and i have bourned my icharger 106b....:-(.
Do you think that it's repairable?
That is hard to say without actually looking at it to see what popped and let out smoke, etc.
Maybe, maybe not. Hopefully only a voltage regulator on the inside went. So the choice is to send it in or get a new one. Yes it is a hard decision for that.
Mar 01, 2012, 07:53 PM
You can try to fix the problem according to the following post:
https://www.rcgroups.com/forums/show...ostcount=11899
Junsi
Mar 02, 2012, 09:35 AM
Temprature sensor and USB cable for iCharger 306B
Just a quick question. Where can I purchase a temperature sensor for the iCharger 306B, and a replacement USB cable for it? thanks
Mar 02, 2012, 09:45 AM
Raehm's Avatar
Icharger 106B
I accidently left a lipo connect in a plane, and now my icharger says "bal low".
Can I recharge this battery? Any special instructions for my icharger?
Thanks!
Mar 02, 2012, 09:58 AM
Southern Pride
everydayflyer's Avatar
This happens all of the time and thus like many FAQ is covered by a Sticky.
https://www.rcgroups.com/forums/show....php?t=1074181
Mar 02, 2012, 10:16 AM
BrainFart RC-Pilot
TreeDiver's Avatar
For clumsy people like me... it would be handy if the balance board has the 'pins' which are fully open at the connector side (board lead connector to iCharger) would be covered.
It happend to me that a main lead dropped at the balance board and did hit these pins!
I covered it now with duck tape...
But maybe it is only me... being clumsy indeed?
Mar 02, 2012, 10:34 AM
Raehm's Avatar
Thanks for that. But can you point me to a specific post on this subject?
Mar 02, 2012, 11:08 AM
Woody_99's Avatar
I share your feelings about all the exposed pins on balance and parallel charge boards.
I used some very small ID and OD silicone tubing and put a piece over each one of the exposed, none used pins. I only use 3S, so I had a lot of pins to cover on the parallel board, but now there is no chance of inadvertent shorting.
A low profile snap on cover would be a nice. Not sure what to use. Using a blank male JST might make using the others difficult, but something is needed.
Mar 02, 2012, 11:10 AM
earlwb's Avatar
First post #1 and the first and second URL links in post #1. in the link https://www.rcgroups.com/forums/show....php?t=1074181
Mar 02, 2012, 11:11 AM
Southern Pride
Really is it all that much trouble to click on a couple of links.
Click on Link I provided,
Click on first link there
read first post
https://www.rcgroups.com/forums/show...22&postcount=1
Snip for those who's link clicker is broken
Since I noticed a lot of posts lately on how to recover an over discharged lipo, I thought I would post the method for recovering them.
It's pretty easily actually. All you need to do is get a NiMH charger, and set it to the approximate voltage to your lipo pack. (I.E. 7.2v for a 7.4v pack, or 12v for an 11.1v pack) Now, plug in your lipo, and set the charge current for ~1/3-1/2C charge rate (1/3c for a 1000 mah pack is .33 amps, 1/2C for a 1000 mah pack is 0.5 amps) and start the charge.
You only need to charge the lipo for a couple minutes to bring it back to the proper voltage for your lipo charger to recognise it, and charge it again. It is important that you keep a constant watch on the lipo while charging it with an NiMH charger!
If your lipo is still not recognised by your charger, then charge it a bit more on the NiMH charger.
Mar 02, 2012, 11:49 AM
earlwb's Avatar
Sometimes I think the new generation is becoming way too media dependent. Once someone asked me how to do something with a Lipo pack and charger. So I explained it to them, and they responded back if I could make a detailed video showing how it is done for them.
Mar 02, 2012, 12:24 PM
Southern Pride
Back in my high scholl days to do research for class I often had to drive 15 miles to the main public library, use the dewy decimal index card system and find the books ,magazines , or micro film I needed and locate them all by myself. Today most expect someone else to treat them like they are the only pearson around with a question it seems.
I have stated for years that for the most part the Sticky Thread at the top of every forum are a waste of space. Most never see them much less use them. Everyone can use Goggle or other search engines to fing RC Groups Batteries and chargers but not the Beginners Forum, Power Systems, Radio, DIY Electronics ,etc. etc..
Same questions get asked day after day ,week after week and year after year.
Watch the News and ponder why the cities, counties,states, countries and corporations are in such a state of disarray.
IMO a lot of coulda, woulda, shoulda but sorry I did not know it was my job, task,duty.
Charles
Mar 02, 2012, 03:22 PM
Raehm's Avatar
Here's what I found, what I did, and it worked!
I changed the setting on my charger to NIMH and charged it for a few minutes at 1 amps till i got the voltage back up to about 10.5. I then ran it through my manual balancer and get the cells balanced. Then I charged it individually on my iCharger with standard balance-charge settings, 2.2 amps.
Thanks for your help!
Mar 02, 2012, 04:01 PM
magrinsi's Avatar
Junsi
I have open the 106b.
The only bourned components i think is this
http://www.elettronicashop.it/irf320...0w-623C65.phtm
I attach the photo
earlwb's Avatar
Glad we could help. You did read the warnings about saving a pack like that didn't you?
Best charger/discharger $ can buy namancio Batteries and Chargers 30 Jan 31, 2010 03:52 PM
Power Pacer Battery charger/discharger ACE_McCOOL Batteries and Chargers 4 Oct 22, 2002 12:39 PM
NIB Hitec CG-325 Charger/Discharger/Cycler for 4-9 cells - $39! Jason M Aircraft - Electric - Airplanes (FS/W) 0 Oct 03, 2002 03:29 AM
WTB Good charger/discharger 10 + cells WickedFunRC Aircraft - Electric - Airplanes (FS/W) 0 Sep 05, 2002 08:55 PM
