This thread is privately moderated by Jack Crossfire, who may elect to delete unwanted replies.
Mar 25, 2008, 04:40 AM
Jack Crossfire's Avatar
Operator directed velocity 4 U
Finally got around to making operator directed velocity actually work. U can't just couple the stick to X & Y velocities because wind just blows it off course & increases velocity in the undesirable direction.
The trick is keeping movement on 1 axis. In copter frame, just keep copter X position constant while changing copter Y velocity. In world frame, the axis U want to stay 0 is related to heading.
To simplify the math, just have a fake waypoint farther down the direction line & have her follow it.
Altitude is a different story. Vortex ring states occur after every movement which is long enough to build up translational lift. The workaround is storing the collective integral while hovering & recalling it after the movement is finished. Also adding a bit more to the movement when commanded to stop so the stop is more gradual.
This field is just too small. Lost tail rotor again & ran into a tree. Got a lucky crash right side up.
Sold Novak velocity 4.5R brushless system $185 TonyTypeS Cars - Cars and Parts (FS/W) 5 Jun 21, 2006 01:17 PM
71" F 4 U CORSAIR ...NIB $200 chopperjoe Aircraft - Fuel - Airplanes (FS/W) 9 Jun 30, 2004 10:53 PM
4 U Pro & Rookie Modders....... DarkTari Micro Cars 0 Mar 23, 2003 09:54 PM
We Can! You KAN! KAN950s Built 4 U Now! austinelse Batteries and Chargers 0 Feb 21, 2003 11:53 AM
