Mar 15, 2008, 09:44 AM
Situationally Unaware
muckie's Avatar
Help!
DX7 Program Flap Deployment Speed?
Hi All
I'm building a BH Models Chipmunk using the 3 position flaps mix to drive 2 servos through a reversing Y from AUX1 of a AR7000.
Is there a way to program my DX7 to control the speed of the servos' movement? I'd like to slow the flaps' deployment to a more scale-like speed.
Cheers!
Mar 15, 2008, 11:37 AM
Larry
goliathman's Avatar
no.
Mar 15, 2008, 11:45 AM
You'd need a "sequencer" to go between the RX and the Y to slow the servo operation.
There are few radios that have the capability to program the rate a servo will travel. JR 9303... Futaba 14 MZ... (Maybe the Futaba 12...)
Mar 15, 2008, 12:51 PM
muckie's Avatar
Thanks for the help.
You've saved my sanity - at least for today
Mar 15, 2008, 04:50 PM
Hyperion (and several other manufacturers, but Hyperion is the one I've used) make a gadget called a servo-slow, which can slow the servos right down. I've used one for precisely this application with a DX7 in a CMPro Cessna.
Mar 15, 2008, 06:17 PM
muckie's Avatar
Thanks Andrew - I'll check it out.
Mar 15, 2008, 07:17 PM
pda4you's Avatar
And not all of the servo delay devices work with Spektrum, so ASK first.....
Mar 16, 2008, 11:13 AM
muckie's Avatar
Thanks for the warning, Mike.
Andrew (above) has had sucess with the Hyperion unit and Spektrum - so I think that's the one for me.
Discussion DX7 program freezes up when selecting a particular programmed model LittleG Radios 3 Dec 09, 2007 07:53 PM
Help! DX7 program settings for BTCP Corona ? Wantafly Electric Heli Talk 0 Oct 26, 2007 07:57 AM
FAQ Measured flap cycle speed wmueller10 Ornithopters 5 Sep 30, 2004 03:09 PM
Pitching down on flap deployment Giovanni Day Electric Sailplanes 1 Jun 03, 2002 02:06 PM
