Mar 12, 2008, 11:19 PM
Objects in mirror are losing
1000MPH's Avatar
Help!
Looking for go fast JW60 Mods
Need a JW? www.jwglider.com
I'm looking for advice on 'go fast' mods for my next JW60.
I'm considering fixed trailing edge sections both inboard and outboard to reduce flutter and aerodynamically clean up the tips and the area where the wing meets the fuse.
Should I bother? Could this possibly hurt more than help top speed/flutter?
If it's a good mod, how much? I was thinking about 3 to 6" at root and 3Ē tip.
Also, should the split be 90 degrees to the TE or parallel to the centerline?
I did my Bat parallel but Iím not sure if it made any difference. I didnít get any noticeable flutter at 150+
stu
Mar 13, 2008, 11:59 PM
The sky is my playground
flyboyjimi's Avatar
Stu , my fifty ouncer is just on the edge of being heavy enough in 20 to 30 mph so I suppose a sixty oz. would be strong enough to get through 30 to forty. Its only sixty inches so I dont think alot more weight is going to help It hasnt been the case in my two JWs ive built but I would think there would be a cap as to a weight limit And I would think parrallel to the centerline would be the way to go if your gonna split the trailing surfaces best thing is to build one and see what is does! You may be on to something good luck jimmy in h.B.
Mar 14, 2008, 06:42 PM
My last two JWs were 72 and 74oz. Both flew well but need a good 25 to 30mph wind to get em up on step. I sprayed the fuses on all my JWs with bedliner at work, so piling into to rocks doesn't even hurt em. I've piled them in several times in the 120-150mph range to pick it up and keep flying with no damage.
Would I build one that heavy again? Probably not. They slice through big wind and crappy shear but you lose the ability to make tight turns. At that point it's more like driving a bus. Personally I don't think I'd go over 60oz. if i were to do it again.
My heavy ones hit 150 frequently just from the shear weight, but we seldom get the wind to harness its potential, it really needs 30+mph to start getting into its element.
Happy building
Ryan
Mar 14, 2008, 07:47 PM
1000MPH's Avatar
Thanks for the replies.
All my slopers are heavy, that's a given.
What I'm really looking for are tips to help keep my plane together and controllable at high DS speeds.
I don't mind driving a bus if that bus can hit 200.
Latest blog entry: Windrider Bee Build -...
Mar 14, 2008, 09:38 PM
Maker of TRUE EPP records
L2 Airframes's Avatar
Contact DStunner (Ryan) or Koth( Joe) both have more experience than anyone I know with the JW's, ryan built and flew the record holder at 201, his stuff is smooth and stiff.
good luck
B
Mar 16, 2008, 08:13 AM
Sleedo's Avatar
I would cover it in Karl's (Predator) Burly laminating film. I haven't tried it yet but all of the results have been very positive.
https://www.rcgroups.com/forums/showthread.php?t=821598
Mar 16, 2008, 09:10 AM
1000MPH's Avatar
Thanks Bill, I'm hoping Ryan and JOe will respond to this thread. Both of them have given me tons of advice before. BTW: I think Ryan's JW record is 201.
Sleedo: I'm interested in seeing a burly covered plane. I don't want to start another controversy but IMO, I'm not sure I consider the burly covering in the spirit of the rules (?) for a foam plane. I don't want to break records like that.
Here are a couple of pics of my last JW (78.5oz) and my 163mph Bat (47oz). I can build smooth too.
Mar 16, 2008, 10:38 AM
Sleedo's Avatar
Beautiful work there! I see what you mean, didn't realize you were after a record. I'm placing an order for Burly today I hope and will check it out for myself, no chance of a record out this way unless I head for Mt. Washington. I'm really interested to see how much time I'll save in the building process.
Mar 16, 2008, 04:38 PM
DS= -$ & :-)
Ezza's Avatar
I don't think Burrly is breaking the foamie rules at all. I think once a few people see and feel a burrly covered plane, they will agree.
Burrly is a single layer of soft iron on covering. When you squeeze a burrly covered plane it is actually softer than a double strapping tape and profilm covered airframe.
Eric
Mar 16, 2008, 05:15 PM
Just chillin @ 403 MPH
Jantar2A's Avatar
Eric
I agree,,Iron on is iron on somes thicker and better,,my burly bee is tough but still shreds and tears and has parts I have to iron back down just like any other stuff..
It's good for picking up a little extra weight.
I actually like the softer laminating film Karl sells,,still smoothe but better to work with..JMO
Nick
Mar 16, 2008, 07:00 PM
people will start making noise about foamie rules when you glass wings and surfaces, a new covering sounds interesting especially if it will add to torsional strength
B
Mar 16, 2008, 07:54 PM
gas tires and oil
prplgoat's Avatar
hey stu,
i've been building them with three layers of 3M 893 tape top and bottom. the first one on 45* the second opposite and the third end to end. should be about 58 oz. if you goop between the layers you'll be over 60. mendels came in at 64 like that. i like it at 65 to 68 oz myself. then i lay one piece of scotch extreme over the LE and around the tip to make the LE smooth.
cover the bottom first and wrap a good inch+ around the TE to the top rear. on the top wrap the LE around at least 3/4 ".
4-40 rods with a clevis on each end (helps to be slop free), lots of thinned goop and tape on the nose. pot the fin in with epoxy.
225mg or 5245 servos fit nicely.
they were going 140 mph + easily last week!
probably stuff you already know stu!
marty
Mar 17, 2008, 07:44 PM
1000MPH's Avatar
Nice looking planes Marty. I see you build porkers like me.
Notice any flutter at those speeds?
What are you using for your CG?
All ya'll are probably right about the new covering but I'm a slow learner and tape/monokote is what I know, what I'm good at, and what I'll stick with on this build.
My planes are strong and stiff enough to reach 200, what I'm looking for is reducing drag and flutter as I approach those speeds.
stu
Mar 17, 2008, 08:59 PM
Jantar2A's Avatar
antagonistic post, but real as allways
stu
Yo dude,, My strongest recomendation is that you use some good digital servo's,,this will be your best freind for reducing flutter,,
Just for Stuff and grins,,I'll be at weldon with a new JW built just for going 250mph + in about 2 weeks if you really want to see what it takes to make a JW go really FAST!,,,,Be there
Nick
Mar 18, 2008, 12:17 AM
DS= -$ & :-)
Ezza's Avatar
Nick
Hey Nick, are you going to release any photos of the JW? Love to see it.
Eric
Looking for a FAST Eagle F15 RTF bmaaa Pusher Prop Jet Models 4 May 10, 2005 06:30 PM
Looking for a fast .60 size engine shawn45 Engines 3 Feb 23, 2005 09:27 PM
Looking for small fast profile depron plane Mac8 Foamies (Kits) 3 Oct 12, 2004 07:53 AM
Looking for a fast, sport plane that has very minimal build?? argarre Sport Planes 9 Jul 31, 2004 01:48 AM
looking for something FAST? Tram High Performance 7 Dec 06, 2001 04:18 PM
