Mar 10, 2008, 07:20 AM
Bleriot's Avatar
Multiplex Easy glider PRO
Hi. I have seen this posted by a member in the U.K. Does anyone know if this is available in the U.S. yet and if so ..where? Regards
Mar 10, 2008, 08:52 AM
The original Flying Pigs Sqd.
Up&Away's Avatar
Are you sure you are not mixing easygliders here? Windrider makes an Easyglider (2Ch, lots of dihedral) and an Easyglider PRO (3Ch, almost nodehidral).
To the best of my knowledge Multiplex has an Easyglider and an Easyglider E (a glider and an electric glider resp.)
Mar 10, 2008, 11:27 AM
He is not confused, but I do not think it is in the USA yet, it takes a few months.
Keep checking towerhobbies and other resellers.
Mar 10, 2008, 11:57 AM
Up&Away's Avatar
So what's a MPX Easyglider Pro then?
Old Mar 10, 2008, 12:11 PM
hobie14
A moderator felt this post violated the following rule: Excessive Advertising (Over-competition).
Mar 10, 2008, 12:37 PM
Retired USAF
cynjon's Avatar
Here's a build thread by a guy who has one already...
Mar 11, 2008, 12:32 PM
U.K. or New Zealand
FlyingKiwi22's Avatar
Hello
Just about to start building one of these
What do people suggest if you want to make one of these pretty rapid ?
Would be interested to know what set up have been tried and results.
Thanks in advance
DM
Mar 11, 2008, 01:48 PM
hobie14's Avatar
Originally Posted by FlyingKiwi22
Hello
Thanks in advance
DM
are you subscribed to ..... https://www.rcgroups.com/forums/show...56040&page=164
The EG Pro is coming up more and more in the thread as availability becomes better .....
Mar 11, 2008, 02:49 PM
DLG Fan
AZ_Astro's Avatar
I e-mailed Multiplex to ask when it would be available in the US. Their response was: "We are hoping to have the kit in stores by mid to late summer."
My e-mail to Multiplex follows. There is an interesting link to a hobby store in England that gives a lot of details about the EZG Pro, including two brushless variations. See the link below.
QUOTE Over at the on-line RCGroups/EZone we have seen that europe now has a new version of the EZGlider Electric, the PRO version. The pro version apparently has a modified/strengthened nose that will accept two choices of brushless motors.
Here's the website from a british hobby store: http://www.modelspot.com/mpx/easyglider.htm
I am wondering if and when the PRO version will be available in the US? And if there are any details about the pro version.
Thanks! END QUOTE
I am guessing that Hobby-Lobby and/or Tower will have it.
Mar 11, 2008, 09:00 PM
Dr Kiwi's Avatar
Hello
Thanks in advance
DM
Perhaps you could try one of the new ARC 36mm motors - Klique has test run one in his 60" wing:
"The ARC was pulling 69 amps at 21,000 rpms on an 8/4 E static on 4s 5000mAh, and was cool to the touch after a hard flight."
Jul 05, 2008, 08:16 AM
Slave to Gravity
frank3246's Avatar
Easy Glider Pro power train
I'm trying to assemble a good 'power train' for the Easy Glider Pro. However, as the plane is essentially a new model, I'm finding the details difficult to find.
I've read others recommend the Turnigy 35-36C 1100kv outrunner ($25) and the Turnigy Plush 40a ESC ($34), both from HobbyCity. That leaves the folding prop setup, which is where I'm seeking help...
- I think this motor can turn any folding prop from a 10x6 (quickly enough) to a 12x6 (pulling under 40a) on this plane. Is this true?
- The plane has a 55mm (2.2") nose, so calls for a 55mm spinner. I think the Cularis does as well.
- The above motor has a 4mm shaft, so I'll need a 4mm collet to power the prop.
I see that Mutiplex offers an Easy Glider Pro 55mm spinner/blade holder/4mm driver (part# 73-3500) intended for the 10x6 blades (part# 73-3490) that appears would work perfectly, but is not available anywhere is the US. Mpx also offers 12x6 blades (part# 73-3173), but I don't know if they'll fit the above spinner set. I think an 11x6 or so prop would be optimum.
So what folding prop set-up do you recommend? Where can I find it -- with a 55mm spinner -- for a good price (maybe $35)? Or perhaps part# 73-3500 will become available in the states if I just wait?
Finally, what are the Hitec servo equivalents to the recommended Nano-S (2) and Tiny-S (2) Multiplex servos? Why Mpx won't include this info in their manual is beyond me. Thanks!
PS: Planning to use 3S 20C ~2100Mah LiPos
Frank
Jul 05, 2008, 09:31 AM
hobie14's Avatar
Originally Posted by frank3246
...... what are the Hitec servo equivalents to the recommended Nano-S (2) and Tiny-S (2) Multiplex servos? Why Mpx won't include this info in their manual is beyond me. Thanks!
Frank
Nano-S is HS-55
Tiny-S is HS-81
Jul 05, 2008, 09:50 AM
aka MadMan
rjmanzuk's Avatar
One option ...
...That leaves the folding prop setup, which is where I'm seeking help...
Frank
Frank, I've had terrific luck listening to the recommendations by the team at Atlanta Hobby in all my ARF power train selections so far (PA Addiction, PA KMD, E-Flite Pitts Model 12, and even my ModelTech Fledgling), and here's a link to what they recommend for the Easy Glider PRO (which I plan to buy as soon as they get in stock):
http://www.atlantahobby.com/shopexd.asp?id=7669
Notice that a few spinner options are suggested in the 42-47mm range; and for the motor they recommend, they suggest 13x7 cam folding blades.
Throw that mix into your hopper and see if you like what they offer.
Jul 05, 2008, 10:34 AM
Slave to Gravity
frank3246's Avatar
Originally Posted by hobie14
Nano-S is HS-55
Tiny-S is HS-81
Thanks for the info. I see that Tower has the new HS-82HD servo (karbonite gears?) as part of the EZG Pro Flight Pack, but even the Hitec Web site has limited details on it. Looks to be a replacement for the HS-81, at the same price of $16.49. I have HS-81s in my TwinStar, working great.
Jul 05, 2008, 12:14 PM
I have the easy star, the EZG, &the EZGE and I found it alot easier and sometimes cheaper to just buy the power packs that are made for the aircraft. I think the tuning pack I'm getting with my EZG PRO is a good price for what you get. Not bad in my book.
Article Multiplex Easy Glider Electric ARF Review Michael Heer Electric Sailplanes 59 Aug 09, 2011 02:22 PM
For Sale NIB Multiplex Easy Glider Pro w/NIB HiMax HC2816-1220 Motor & Multiplex BL-27/II ESC Tank52 Aircraft - Sailplanes (FS/W) 13 Feb 24, 2008 09:20 PM
Multiplex Easy Glider Electric Sherwood Electric Sailplanes 55 Apr 23, 2007 11:08 PM
For Sale Multiplex Easy Glider Electric PLATINUM Aircraft - Electric - Airplanes (FS/W) 16 Sep 09, 2005 05:05 PM
Multiplex Easy Glider - looks like a good durable plane for slope and thermals. artmonster Sailplane Talk 5 Apr 26, 2005 06:11 AM
