6 channel vs. 8 channel receivers - RC Groups
Mar 09, 2008, 03:42 PM
xman2004's Avatar
Question
I have a Flinton Extra 300 (39.5" wing span) - which receiver should I use in it?
Will the 6 channel receiver have enough range to fly this plane? Or should I just use the 8 channel one?
Mar 09, 2008, 06:10 PM
It depends how far you are going to fly it!
Mar 09, 2008, 06:53 PM
xman2004's Avatar
Yes, well... I am not sure... This is my first electric and while I have flown it last year on 72mHz I cannot say if I kept it under 1000', and since I had full range receiver in it I really was not concerned with range.... and since I have one of the XPS 6 channel receivers I might as well use it in this plane. Just want to make sure it has enough range for this size plane.
Mar 09, 2008, 07:36 PM
You can call me FANBOY!
Where did you fly it? An interesting thing I did one day was to pull up our field on Google Earth and take some measurements. 1000' doesnt sound like much, but its a pretty long way to see something that size. So to answer your question I think yes it would, be like previously stated it depends on what you are going to be doing with it.
Mar 09, 2008, 08:40 PM
xman2004's Avatar
Well, I guess the trick will be to keep it in range... I just looked up the specs for the 6 channel receiver on XPS website - it states for air range 1500', line of sight.... I do not think I will be able to fly this thing to 1500' without a pair of binoculars
Apr 21, 2017, 07:43 AM
6 or 8 channel receivers
With a small aircraft like yours, a six channel is more than sufficient. I usually reserve the 8 channel or higher receivers for much larger aircraft.
Apr 21, 2017, 11:12 AM
First of all, the reference for the first post in this thread was for the original 6 channel park flyer receiver, not the Nano receivers that we offer todya.
The 6 channel Nano receivers replaced the original 8 and 10 channel receivers because they are a substantially better receiver! The Nano receivers operate down to 1.8 volts (vs. 2.9v of 8/10 channel receivers), and have 25% better range.
You can gang up as many Nano receivers as you want to obtain extra channels. For example, if you needed 16 channels you could use three Nano receivers together to get 18 possible outputs.
Apr 22, 2017, 06:08 AM
I have used both the Nano and the Sailplane 8 channel receiver in my unlimited class sailplanes and the only advantage the Sailplane receiver has over the Nano is a much better antenna. Nano antenna are a real pain in skinny sailplane fuselages. Sailplanes normally spend a lot of flying time at extreme range and I have yet to experience any range problems with any XPS receiver. I have been flying only XPS receivers for the last 10 years.
Apr 25, 2017, 09:03 AM
PGR
PGR
Low AltiDude
PGR's Avatar
Amen !
Pete
Apr 25, 2017, 11:50 AM
That's why there is the RFU. Smaller than a sailplane receiver, and much better antenna system!
Futaba T6XHs PCM 6 Channel Radio Set n Eco 8 daddyhobby Aircraft - Electric - Airplanes (FS/W) 1 Apr 07, 2003 01:04 AM
FS: Airtronic (92785 FM) 8 Channel Receivers bitzerj Aircraft - Electric - Airplanes (FS/W) 2 Dec 31, 2002 07:41 PM
6 cell VS 8 cell king nine Parkflyers 2 Dec 06, 2002 10:48 AM
WTB: 6,7,or 8 channel Transmitter sizam Aircraft - Electric - Airplanes (FS/W) 1 Sep 10, 2002 07:35 PM
6 cell vs 8 cell ?? KevinM Electric Plane Talk 6 Jul 03, 2002 11:49 PM
