Feb 29, 2008, 07:48 PM
One cell short of a Pack
steve1814's Avatar
DX7 Programming help - Flaps
Folks, I need your help...
Here is the scenario: I have a Electro Telemaster with Flaps that I am using a AR6200 RX with. I am using both the aileron channel and Aux1 for the two aileron servos for differential . The flaps are on the Gear channel and I can only have deployed/not deployed as an option for the flaps. Is there a way to map the gear channel onto the 3-pos switch? If so, I'd love to know how to do it!
Thanks!
Cheers,
Steve
Feb 29, 2008, 08:13 PM
I have what you are looking for set up for a 7 chan Rx, but the following might work.
1) Set up aux2 with its input selected as 3 pos switch.
2) Set up this mix - Gear to Gear (Up=-100, Down=-100, Offset =0). This inhibits the gear switch.
3) Set up another mix - Aux2 to Gear (Up=100, Down=100, Offset = 0).
This should get the 3 pos switch sent out on the gear chan.
Alan
Question DX7 Programming with Seperate Flaps UnPossible Radios 7 Jun 27, 2009 05:24 AM
Discussion DX7 Delta programming Help Sim69 Australia 2 Oct 08, 2007 02:48 AM
Discussion AR7000/DX7 on an FVK Kamelot -- programming help brobak Radios 1 Jun 30, 2007 11:00 AM
Discussion DX7 - GY611 programming help! Can't get to 100% gain. Vertical Radios 3 Mar 06, 2007 02:45 PM
JR 8103 Programming help needed? franz Electric Plane Talk 8 May 08, 2001 10:13 PM
