Feb 17, 2008, 03:36 PM
agriebel's Avatar
Build Log
B-52 pusher
Well, another snow storm so I thought it was time for a new project a B-52H.
I downloaded superhornets plans and he is right, very quick build. I got this all done in one day!
I am trying to decide between a himax 2015-4200 or a wegard 2212-06 motor. They both weigh the same. I was really surprised. Any input on the motor would be appreciated.
All of the parts came of 2 sheets of depron. The hardest part will be the engines.
Feb 17, 2008, 04:46 PM
man, you're like a building and design machine!!! keep up the frenetic pace! '52 looks cool.
-beanie
Feb 17, 2008, 06:23 PM
agriebel's Avatar
Ok, it is coming along really well. The slot for the wing was a little too short so I lengthen that. Now I have started on the engines. I'm thinking that maybe I should drill out the front of the engines to give them more of a scale appearance.
I thought about mounting the engines with magnets but I wouldn't be able to use the over the wing part of the pylon. The engines sit about 1 1/2" above the ground. I wonder if that will be enough?
None of my CF is long enough for the wing. So off the the LHS tomorrow. I like the way the CF strip looked vs CF rod so I will go with that again.
Feb 17, 2008, 06:47 PM
AMA - 734492
EricClark's Avatar
This is great! I haven't really seen a B-52 built before... especially out of foam. B-52s are cool so I'm watching.
Eric
Feb 17, 2008, 07:03 PM
Eric
stacker had a nice B-52 that he brought to Superfly VI. here are a couple pics of it. i believe it's foam.
-beanie
gromitvt10's Avatar
what are the dimensions? where did you get the plans? looks great so far.
Kyle
Feb 17, 2008, 07:04 PM
EB-66C Team Member
J Morgan's Avatar
Yep, stack's is foam and EDF!
J
Latest blog entry: A2D Skyshark at 1/8th scale
Feb 17, 2008, 07:35 PM
500FT & Climbing
SuperHornet's Avatar
Kyle
My plans and dimensions are on this page,
https://www.rcgroups.com/forums/show...=479218&page=2
cheers
SuperH
Feb 17, 2008, 07:47 PM
agriebel's Avatar
It's 40" in length, and wing span of 45"
That stacker can really build a plane!
Great plans superhornet!
Feb 17, 2008, 07:59 PM
AMA - 734492
EricClark's Avatar
-beanie
Cool.
Feb 18, 2008, 07:28 PM
agriebel's Avatar
Some more work done today. Installed the CF Strips into the wing, attached the horz stab and mounted the wing. I also finished up on the engines. I also test fitted one on the wing. I was planning on gluing the pylon to the wing then use magnets to hold the engine to the pylon. I hope this is the best way.
Feb 18, 2008, 09:47 PM
500FT & Climbing
agriebel ,
Looking good so far.
Are you going to put in a bomb bay door to drop things out of the sky....?
I had Nav lights on mine and flew it late at night & dropped glow sticks from hight up. ausume fun
http://www.rc-cam.com/navlight.htm
SuperH
Feb 18, 2008, 10:10 PM
agriebel's Avatar
I wasn't planning on a bomb drop or nav lights. I have a hard enough time flying during daylight hours.
Feb 19, 2008, 11:27 AM
agriebel's Avatar
I'm now test fitting the engines. Now if I can just figure out which motor to use.
choice 1
wegard 2212-06 outrunner with 6x4 prop
choice 2
himax 2015-4200 with 10x7 prop
weight is the same for both. I've used the wegard on other prop jets with good results but with those 8 engines hanging out there it is a lot of drag. Weight without paint or battery is 13.2 oz
Any suggestions?
Feb 19, 2008, 12:40 PM
killickb
killickb's Avatar
Here's one --- GreenAir Design, full house pusher. Flies great.
B-52 Update flailing Scale Kit/Scratch Built 25 Mar 22, 2010 04:47 AM
Edf B-52? efarmer Electric Ducted Fan Jet Talk 95 Nov 21, 2009 06:54 AM
Discussion B-52 Pusher idea wing_man Pusher Prop Jet Models 41 Mar 13, 2006 09:10 AM
B-52..50! dorysch1 Electric Ducted Fan Jet Talk 14 Dec 03, 2001 11:29 PM
eBay B-52 plans gutboy17 Electric Ducted Fan Jet Talk 3 May 23, 2001 02:08 AM
