Cessna Skymaster 337/O2 - Page 4 - RC Groups
Nov 26, 2016, 08:42 PM
vbearn
Sorry to be so long in replying.
The best way to describe it construction is a 'stressed skin monocoque' or to put it simply carvel planking as in ship building but using 3 mm Depron sheet!
The wing is fairly conventional construction - spar, ribs and sheeting except the flanges of the balsa/Depron/balsa spar are incorporated into the wing skin itself to give the maximum possible spar depth.
The bottom wing skin with the balsa spar flange inserted in to it.
Description:
The Depron ribs and shear webs added along with the top spar flange and leading edge skin.
Description:
Each wing is now quite rigid and strong enough to handled.
With the tail booms added (they are also hollow Depron) the wing halves can be joined.
Description:
With the aileron servos installed the top wing skin is completed and the fins and tail plane added.
Description:
The elevator servo is buried in the centre of the tail plane. The servo wire runs up the RH tail boom. It is flown bank and yank so there is no rudder.
The fuselage is built as a half shell on formers over the plan.
Description:
Once it is sufficiently planked it can be lifted and the formers for the other side added.
Description:
Before the planking progresses too far the motors and ESCs are added.
Description:
Description:
The whole wing assembly can then be fitted to the fuselage and all the planking completed once the load carrying wing struts are fitted.
Description:
The battery and radio are in the cockpit.
Description:
All covered by a one piece Depron "canopy" that is held down with magnets.
By no means a beginners plane to build but the resultant structure is very light so only requires quite modest power, about 260W in total (but that's 130W/lb!) and is plenty strong and stiff enough for spirited aerobatics.
I hope this helps.
Apr 19, 2017, 09:53 PM
Nice building and flying!
Up!
Jul 30, 2017, 11:09 AM
Quorneng. How many cm of chord of wing?
Aug 16, 2017, 09:48 PM
Originally Posted by Quorneng
vbearn
Attachment 9556118
Attachment 9556120
Attachment 9556153
Attachment 9556163
Attachment 9556170
Attachment 9556171
Attachment 9556190
Attachment 9556192
Attachment 9556198
Attachment 9556206
I hope this helps.
Where is CG ? You mean 32 oz that is 907 gr?
Build Log Dornier Do335 JMPaccassi Foamies (Scratchbuilt) 49 Nov 25, 2008 06:12 PM
Contest 2008 Multi-Motor Contest Rusty-Gunn Foamies (Scratchbuilt) 98 Mar 20, 2008 12:23 PM
Discussion The World Model's Cessna EP: Build Log. Pipercub18 Electric Plane Talk 11 Jul 09, 2006 11:26 PM
Discussion World Models: Cessna Skylane Build Log. Pipercub18 Parkflyers 0 Jul 05, 2006 10:56 PM
