New foamies from MPX 2008 - Page 8 - RC Groups
Mar 19, 2008, 07:21 PM
The motor being up front will help (I am used to an EZ Star). We shall see once owners start reporting what motors and batteries they used...
Mar 20, 2008, 12:38 AM
I know its probably been asked already...but any clue when the easyglider pro will be available in US. I am debating on getting the easy glider electric or waiting for the pro...any word??
Mar 20, 2008, 02:50 AM
Jurgen Heilig's Avatar
I would definitely wait for the Pro version.
Jürgen
Mar 21, 2008, 09:51 AM
a few comments back there were guesses of having them in the us by late summer at the earliest.
Mar 21, 2008, 09:53 AM
Not your average DiggsyBear
Diggs's Avatar
Jürgen
Skimmed the PDF for the pro, but not knowing enough about the standard version, what are the main advantages of the Pro?
Diggs
Mar 21, 2008, 01:15 PM
dmt
dmt
dmt's Avatar
If you don't need a brushless in-runner, the regular EZGE works fine, imo. I'm sure those looking for higher power-on peformance will appreciate the 'Pro', however. As for the new wing connectors, they're probably terrific, but I pretty much always leave my wings connected anyway, so it's not a factor for me. I'm not at all trying to run down the Pro, but just offering my opinion that the regular EZGE is pretty cool as is, and works fine. If the regular power system is fine for you, and you usually will leave the wings attached, there probably isn't any big advantage to the 'Pro' version, I'd think.
Mar 25, 2008, 01:40 PM
Diggs
The Pro has a re-enforced, much more spacious nose section to allow for modern direct drive brushless outrunners. The battery space is also much bigger. The new spinner provides better aerodynamics, especially as the prop blades fold much better to the contour of the fuselage.
Most people want to go brushless anyway. The Pro comes without drive unit and is cheaper than the old Electric version.
Jürgen
Apr 10, 2008, 01:42 AM
hobie14's Avatar
Jurgen ..... any idea when the new MPX models are going to be widely available in Europe? ......
Apr 10, 2008, 02:58 AM
Widely available - I don't know. Otherwise the dates are on the MPX homepage.
Jürgen
Apr 10, 2008, 03:01 AM
New foamies Video Action
The German Indoor Aerobatics Championship 2008 and the Lotto-Mons-Expo WAG Selection Contest slowed down the video processing from March, but here we go:
Videos from the FMT Neuheitenshow in Sinsheim:
EasyCub: https://www.rcgroups.com/forums/showthread.php?t=847490
Mentor: https://www.rcgroups.com/forums/showthread.php?t=847481
ParkMaster 3D: https://www.rcgroups.com/forums/showthread.php?t=847487
EasyGlider Pro: https://www.rcgroups.com/forums/showthread.php?t=847484
Blizzard: https://www.rcgroups.com/forums/showthread.php?t=847478
Enjoy!
Jürgen
Apr 10, 2008, 03:35 AM
glucoseboy's Avatar
Thank you Jurgen for the wonderful videos.
I noticed in the one for the Blizzard, that there were two instances where they rocketed straight up out of the video frame.
Were the climb rates really that fast? (or is it a video compression artifact)
Apr 10, 2008, 03:59 AM
They were indeed that fast - and considering that I usually followed the slower one of the two ...
Jürgen
Apr 10, 2008, 04:53 AM
hobie14's Avatar
Enjoy!
Jürgen
Wow !!!!!! .......
those videos will sell a lot of MPX planes ......
Apr 10, 2008, 05:17 AM
dmt
dmt
dmt's Avatar
Wow, those Blizzards were pulling some serious G's at times!
How do they fly power-off? Or are they really supposed to be powered planes with a glider-like form.
Apr 10, 2008, 05:27 AM
hobie14's Avatar
quote ......
"A high-performance hot-line model exploiting ELAPOR® technology. Modern brushless motors in conjunction with high-performance LiPo batteries provide the power for vertical hand-launches with either of the recommended power systems.
Breath-taking high-speed passes - especially with the upgrade power system - and a superb glide angle thanks to the MPX wing airfoil, with a thickness of only 8.9%.
Neither is the model a slouch when it comes to thermalling - the BLIZZARD’s low all-up weight and carefully optimised aerodynamic layout enable the machine to keep up with many a conventional “floater”. The aeroplane has great aerobatic potential, but is nevertheless easy to land slowly - “like a feather” - if the braking system (both ailerons raised) is used.
At the slope you can really let the BLIZZARD tear up the sky in good lift.
The wings feature two CFRP spars and four supplementary spar caps which endow the structure with great torsional rigidity and bending strength, while the fuselage features GRP longerons and a large number of innovative plastic parts. The net result is a highly practical aeroplane for everyday flying.
Features
*Ultra-broad speed range
*Low sinking speed, good glide angle
*Kit includes supplementary “glider nose-cone” with aero-tow option
*Landing aid - both ailerons raised
*Can be finished using any standard spray-can paints after prior treatment with MULTIprimer # 60 2700
*Pre-fabricated moulded ELAPOR® parts
*High-quality plastic components
*Aileron servos connect automatically when the wings are attached to the fuselage
*Optional second elevator servo for supplementary rudder function
Specification:
*Wingspan 1380 mm
*Overall length 910 mm
*All-up weight min. 725 g
*Total surface area 19.4 dm²
*Wing loading approx. 37.4 g/dm²
*RC functions Aileron, elevator (optional rudder), throttle, spoilers (both ailerons up) "
end quote ......
2 new elapor planes from MPX for 2005 prondel Aerial Photography 0 Feb 07, 2005 09:16 AM
New jet? from China Model Exposition kwan Electric Ducted Fan Jet Talk 17 Oct 11, 2001 12:22 PM
New M100 From Parkflyers.com?????? Planeboy P51 Parkflyers 9 Sep 15, 2001 10:43 AM
New Guy from Lubbock Introduction radix2 Electric Plane Talk 6 Jul 15, 2001 07:01 AM
new antenna from www.Azarr.com Fred Bronk Parkflyers 8 May 05, 2001 03:21 PM
