Feb 03, 2008, 05:32 AM
7.4v 15c Mystery battery's two mysteries.....
I have two mystery 7.4v 15c batteries, "2S YT703048HHH" and "2S TO3466P4H3R". I tested one battery whose model # is "2S YT703048HHH".
There are two mysteries.
1. I read that "2S YT703048HHH" is a better battery.
http://www.heliguy.com/Forum/mystery...ad-t17729.html. Please add your opinion about this issue.
2. The battery whose model # is "2S YT703048HHH" is 15C. However, I found batteries which have the same model # but is 12C.
Could anybody confirm which is right ? 12C or 15C?
I tested "2S YT703048HHH" which seems to be reliable and is stronger than the 5 other batteries which I used so far. and I am personally satisfied with it.
I tested the battery with my storm launcher and walkera 5#4.
After I tested "2S TO3466P4H3R", I will post my brief opinion about it.
I hope to listen to your opinion about this mystery battery...
En.
Feb 03, 2008, 01:54 PM
About 2S TO3466P4H3R....
I tested mystery battery whose model number is "2S TO3466P4H3R".
It seems like a 3C battery..... It does not provide 15C power to my storm launcher. The battery is cut off at a full throttle. The SL flys for several seconds at half-throttle and the battery is cut off again...
When you buy mystery battery, please check the battery's model number....
Mar 07, 2010, 11:51 AM
I know this topic is a little old but I have a question, please.
I'm thinking about buying a Mystery battery and I want to buy the good one.
I found a Mystery battery with the following model number: MY703048HHH.
It's neither mentioned above.
Would you know if it's a good one or not?
Thanks.
Mar 07, 2010, 12:02 PM
I have 2 of the Mystery 2S900 that I bought from Deal Extreme last year: http://www.dealextreme.com/details.dx/sku.10783
I use them for my foamy Nutball. They seems to run out of 'oomph' at around the 5 minute mark. At that point they don't have enough power to hover the Nutball. My 2S800mAh Esky lipos and 2S850mAh Outrage lipos will have plenty of power up to 10-12 minutes. I never get them below 3.7v a cell and they're never warm after a flight. I'm not sure what's going on with the Mystery lipos but I probably won't buy them again.
Mar 07, 2010, 12:08 PM
so, Mystery doesn't seem to be an option.
Turnigy seems to be a good and reliable brand, right?
have you heard anything about?
thanks.
Sold 7.4V 2S 1300ma Lipo's (qty-2) 10amp Dampy Aircraft - Electric - Batteries & Chargers (FS/W) 5 Apr 02, 2006 09:14 PM
F/S Kokam 7.4v 1200mah LiPoly battery (4amp) Gizzmoe Aircraft - Electric - Airplanes (FS/W) 2 Jan 12, 2005 11:56 PM
ESC for 7.4V Li-ion battery hty Batteries and Chargers 1 Apr 26, 2004 02:31 AM
Kokam 7.4V 2040mAh LiPoly battery pack (2s2p) kyril Aircraft - Electric - Airplanes (FS/W) 1 Aug 05, 2003 11:33 AM
Kokam 7.4V 2040mAh LiPoly battery pack (2s2p) kyril Aircraft - Electric - Airplanes (FS/W) 1 Aug 04, 2003 10:11 PM
