This thread is privately moderated by Jack Crossfire, who may elect to delete unwanted replies.
Jan 27, 2008, 04:23 AM
Jack Crossfire's Avatar
The war on assembly language
For assembly language hints, go to http://www.rentron.com/Myke8.htm
Obviously not used much since 1999.
So far the expanded Vicacopter assembly language seems to be working. It does the common Vicacopter sections at 70khz while the C port only did 16khz. With GPS parsing at 4Hz, it drops to 55khz.
To save clockcycles, probably going to leave navigation units in the uBlox's binary format throughout the program. Running out of things to do on Vicaglider without buying the expensive stuff. Going to be quite a hassle to swap in Vicacopter's Xbee.
Another possibility is a small, second PIC specifically for either software UART or PWM. Note the 4 PWM outputs on the PIC are for driving an H bridge. They don't have independant duty cycle.
For Vicaglider the extra weight wouldn't be a problem. Her main processor could go back to C and do sort of the Gumstix role on Vicacopter.
Disadvantage: more complex, more expensive, less Vicacopter reuse.
Now for a Gootube demo of servo jitter with the Vicaglider loop at 70khz. We have 1 servo for testing PWM.
Servo jitter at 14usec resolution (0 min 11 sec)
New in war on terror uncled Humor 1 May 23, 2003 01:50 PM
Ireland declares WAR ON IRAQ!!!! Dave Campbell Humor 2 Feb 24, 2003 01:19 PM
It is not easy opposing the war on terror Mr Mootsie Life, The Universe, and Politics 32 Mar 24, 2002 07:52 PM
