This thread is privately moderated by Jack Crossfire, who may elect to delete unwanted replies.
Jan 14, 2008, 05:01 PM
Jack Crossfire's Avatar
C 4 U
So moved the common parts of Vicacopter's PIC code to C for Vicaglider, using SDCC as the compiler. The complete Vicacopter code is 2940 bytes in assembly. The common sections alone went to 7600 bytes in C. Inefficient translation of C has always destroyed PICs.
It's probably too slow in C, so that ends any more Vicaglider until test hardware exists. Vicaglider is history until we recover the cost from...
Vicacopter II's airframe arrived after 10 days, complete with smashed canopy. The Align 430XL motor is probably too small to do the job, so we'll be studying governor mode on the old Phoenix 45.
Jan 15, 2008, 11:50 AM
The Stock 450 motor
The stock 450 motor is plenty powerful.
I did some work on an autopilot on the 450, and I gave it up for the 600 because the tail rotor belts kept failing. Plenty of power to lift 18oz, but
the extra load on the tail rotor kept wearing out the belts. (450 SE)
Paul
Jan 15, 2008, 01:15 PM
Looking forward to replacing tail belts.
Jan 15, 2008, 03:43 PM
Outrunner motor (like your 430XL) are always smaller and lighter then inrunner motor for the same output power. These days, outrunner motor are far more popular then inrunner in Heli application. They give more power but are generally less efficient.
430XL is decent motor, you will see.
Kos
$1 Futaba Conquest R/C 4 Channel FM Radio FP-4NBF w/Flight Pack eBay LexTalionis Aircraft - General - Radio Equipment (FS/W) 5 Sep 15, 2004 07:01 PM
71" F 4 U CORSAIR ...NIB $200 chopperjoe Aircraft - Fuel - Airplanes (FS/W) 9 Jun 30, 2004 10:53 PM
4 U Pro & Rookie Modders....... DarkTari Micro Cars 0 Mar 23, 2003 09:54 PM
We Can! You KAN! KAN950s Built 4 U Now! austinelse Batteries and Chargers 0 Feb 21, 2003 11:53 AM
