This thread is privately moderated by 62pilot, who may elect to delete unwanted replies.
Jan 08, 2008, 05:27 PM
Don't look at me like that....
62pilot's Avatar
f-14 schemes
http://www.f-14association.com/squadrons.htm
http://www.freewebs.com/fighterjetpics/
-Set up by Throttle Stick:
Switch on the transmitter and check the
throttle stick is at Max position. Connect the main power pack and switch on BEC (for the controllers
with BEC). After a piece of music, you can follow the prompting sound to begin programming. When
hear a prompting sound (sound 3 times), move the throttle stick from high to low position quickly. You
should hear a ‘beep’, your setting is done. Move the stick back to Max position, waiting for the
prompting sound and repeat above steps for other settings. After your setting, keep the stick at lowest
position for 5 seconds, you will hear a piece of music. Now, you can begin flying.
Prompting Sound:
1. Brake On: - - -
2. Brake Off: - - - - - -
3. NiCd / NiMh: .- .- .-
4. LiPo: .-- .-- .—
5. Soft Start up: ..- ..- ..-
6. Hard Start up: ..- - ..- - ..- -
7. Soft Timing: … - … - … -
8. Hard Timing: … - - … - - … - -
9. Reset to Factory Setting: .... .... ....
The controllers are supplied with factory setting, Brake Off, Soft start up and Auto timing.
Note: when the first time of using the ESC, or when changing number of batteries, or when
changing battery type, the setting of Battery Type must be done every time.
All Motrolfy info/supplies/parts can now be found at http://www.subsonicplanes.com/
Ken Young took over as the US dealer for Motrolfly since Scott launched a new line of motors for REALLY BIG electrics. And I do mean big!
I'd highly suggest a purchase of the programming card. 30 seconds vs. a few minutes of aggravation was worth it for me. The card is $16.00
Jan 27, 2008, 08:10 PM
62pilot's Avatar
Phoebe A. Lee
Mar 04, 2008, 09:21 PM
62pilot's Avatar
Dec 12, 2008, 01:42 PM
62pilot's Avatar
Phoebe x-mas
Update for F-14 EDF plan buyers. bipeflyer Electric Ducted Fan Jet Talk 6 Feb 11, 2005 02:10 AM
F-14 Scale EDF Whos kit is it ??? F900 Electric Ducted Fan Jet Talk 6 Dec 07, 2001 09:26 AM
F-14 Tomcat EDF,pictures and questions bipeflyer Electric Ducted Fan Jet Talk 13 Jul 14, 2001 06:10 PM
Great Plane F-14 and Learjet conversions sbarrow Sport Planes 1 Jun 24, 2001 08:00 PM
f-14 center of gravity verus center of lift tony houk Power Systems 5 May 14, 2001 01:48 PM
