Hi this is my setup....
Lastest plan 18.0 wing span Motor: Medusa 4000kv (12mm) ESC: Hobbywing Pentium 10a (setup to 15°) Batt: Thunder Power 480 2s 25c Servos: HXT500 (carbon pushrods) Prop: 3x3 GWS Radio: Spektrum weight: still yet ???? But.... This beauty flew perfect! Unlimit vertical! motor runs cool! slow like trainer.. fast like a real f22 ! My favorite plane ever lol...Sorry for my english Im from Puerto Rico. |
Reason: Wing span error 18.0"
some pictures..I make a custom fiberglass engine mount glued to the fuse and fixed motor with plastics straps
Maidened mine yesterday. It was soooooo hot and windy that I didn't do much, just flew it around a couple minutes then went home to the A/C. I had the controls set way too high so things got a little frisky from time to time.
Very nice Mark! I see that motor you have works just as good as the one I use.
Once you get used to the plane, you'll want to turn those control throws back up. I typically fly at 100% on low rate, and 125% on high. Most flying is on low rate, and I flip to high when I want to do really crazy aerobatics. Pat |
Pitch response is insane. I ended up with the battery sitting just a smidge forward of the CG which I think helps. I had it on 60% rates on the first launch and, if you watch, I almost threw the plane into a loop the first time I tried to pull up.
I discovered it doesn't like to be blown sideways in the wind at low speeds. Or, rather, that it likes it just fine but you have NO control authority. Any time I got in trouble, a punch of throttle cleared everything up. As you can see, I was flying mainly slow and close-in, often nearly hovering in the wind. Of course, when I slowed it way down, I lost control authority again. But I'll get the hang of it. Thanks again for all your support. |
Here it is sporting its new cowskin camo paint job in hot pink! |
Yeah I see you've already discovered that you Goose the throttle to regain controll authority, just little blips . Pink Camo huh? Miss Piggy would like.
A guy at our field gave me some foam and asked me to cut him one. It's 6mm so I would like to make it a little bigger . I have enough foam for about 115% size, Steve knows how to resize plans using Adobe #10 but I dont. Anyone able to help. |
Al,
No need to go through all that work. Just build him this one: https://www.rcgroups.com/forums/showthread.php?t=723890 Use a 2212-6 motor, 30A ESC, APC 6X4E prop, two 9-gram servos and a 3S 1300 lipo. That's the perfect combo, same as what I have in the Concorde. Pat |
Thread Tools | |
Similar Threads | |||||
Sold | 3mm White Depron 18 sheets | Twinkletoze | Aircraft - General - Miscellaneous (FS/W) | 1 | Sep 06, 2007 09:57 PM |
Built up 3mm depron aerobatic/3D??? | bcripe1 | Foamies (Kits) | 4 | Sep 03, 2003 08:00 PM | |
3mm depron CAP | MGoddard | Foamies (Kits) | 3 | Sep 01, 2003 07:36 PM | |
Slice BlueCore into 3mm Depron | localbuyer | Foamies (Kits) | 1 | Jul 08, 2003 10:28 PM | |
For Sale | Fs 3mm Depron Sheets | CMT1961 | Aircraft - Fuel - Airplanes (FS/W) | 2 | Jan 28, 2003 01:01 PM |
