View Poll Results: Poll Closed
cloled 0 0%
closed 0 0%
Voters: 0. You may not vote on this poll
Apr 20, 2017, 04:15 PM
Thanks Guys!!!
Great suggestions. Lots of "homework" tonight. I'll let you know. Very good continuing troubleshooting ideas. That's just what I need...Thanks Again-Bob/Bradenton
PS: I had moved that tiny MateCam 808 from the side of the rear hatch to the top of the hatch to keep it out of the water. (Did you see in my video, it go under water!?) I had thought that maybe it was causing some sort of interference but after removing it, the symptoms are still there, even with the multiple Factory Resets...More later...
Apr 20, 2017, 04:30 PM
Always trying to learn
mejmea's Avatar
One other quick thought. Create a second (new) model on your radio and make it a helicopter instead of an airplane (don't delete your first one, just create another). Binding this new model/memory spot to the receiver and see if the same issues exist. The idea is that any default mixing that might be created in an airplane model would not be the same in a heli model. Given the history that you've explained (i.e. that it worked for 2 weeks and then got flaky) there's no particular reason to think that this will fix things but it's just one more thing to try to narrow things down....I'd probably try the previous suggestions first.
Apr 20, 2017, 07:37 PM
R. Nordeck's Avatar
Need another one for our "fleet"; anybody know of one for sale?
Cap'n Narly
Apr 20, 2017, 08:54 PM
Where are you located?
Apr 20, 2017, 09:06 PM
R. Nordeck's Avatar
Wunderful WY !!
Apr 21, 2017, 07:00 AM
Ref: "Oddity for this morning's race:"
Thanks again guys for all the great suggestions. Tried them all and the FlySky Controller/Receiver is still acting the same. Again, very very good troubleshooting ideas. That's just what I needed. Thanks again!!!
So, I put the original Nirvana Receiver back in and used the original Nirvana Controller.
The only issue that I am having is that in the Sail lever mode, the bottom half of the lever travel works great, the Sail arm moves correctly in and out.
However, once I go over the half way point, the Sail arm, already at its "sail-in, tight" mode, cuts in an out. The red LED light cuts in and out too. Seems to be over-stressing the servo so it cuts out/turns the circuit power On and Off as it recycles.
I moved the Trim adjuster all the way to the down position and this helps a bit but if I forget during a race to stop the lever at the half way mark, the Sail is going to start pulling in and then letting loose as the servo cycles On and Off.
Does this just mean that I need to reposition the Sail arm on the servo?
Looks like I'll be racing on Saturday anyway. I'll mount the MateCam 808 and do a posting if everything works out. (However, if I am winning the races, no boats will be in front of me so the Cam won't show anything interesting/HA!) Bob/Bradenton
Apr 21, 2017, 10:11 AM
mejmea's Avatar
The red light going out most likely means that the servo is stalling and drawing enough current to cause the voltage to drop which, in turn, causes the receiver to shut down momentarily until you release the load on the servo. Since the original transmitter isn't programmable at all your solutions are limited.
1) If your sail servo is programmable (and you have a programming box for it) you could change the throw on it electronically.
2) If you can't do 1) you could move the point at which the sheets "attach" to the servo arm inwards. This will give more servo travel for any given amount of sail travel since the arc length path will be shorter. This option may not be practical since the location of sheet pulley is fixed on the servo arm (not sure what you are using for the servo arm for your sails currently)?
3) Someone a few pages back suggested putting a physical stop on the transmitter to prevent you from raising the stick too much - this may be your most practical option at this point.
Apr 21, 2017, 10:36 AM
Ah HA! I remember that post. Thanks for the reminder. I'll play with the arm a bit but will add a "stop" on the Controller to keep me from moving it up too far...Thanks, racing in the morning...Bob/Bradenton
Apr 25, 2017, 03:56 PM
AMA# BR549
rikybob's Avatar
Yet more...
.....Florida sailing!!
Nirvana afternoon sail! (27 min 5 sec)
Apr 25, 2017, 09:55 PM
Need Nirvana 2 keel
I Need a Nirvana 2 keel. If any one has an extra for sell, please let me know. If not, can somebody provide me the dimensions and weight so I can build one? I will not be racing, so it doesn't have to be race legal.
Discussion Vixen yacht. chidago Sailboats 1 Mar 01, 2013 02:58 PM
