This thread is privately moderated by Hostage-46, who may elect to delete unwanted replies.
Dec 19, 2007, 12:34 AM
Hit my smoke....
Hostage-46's Avatar
In Harely we trust...
It seems like ever since the first time I looked at Harely's Genie plans, I pondered, worried, obsessed about the cutting of the cores for the spar. I considered all kinds of wacky schemes to figure out a way to cut the spar with precision.
Finally, as he often does, Harley gave me a gentle nudge, and I just moved on. Sure enough, it was pretty simple. It turns out I can cut within the width of a fine line, any variation is handled easily with a sanding block.
So that hurtle complete, I move on to fabricating the spar, end caps and joiner boxes.
Off tomorrow to Knoxville for a business trip, "working from home" on Friday, I expect to make some progress.
Dec 19, 2007, 11:36 AM
I'm stalled out on a project ( not a Genie ), pondering cutting the spar. What way did you finally do it? Bandsaw? Hot wire? knife? Chainsaw? Ditch Witch?
-eric
Dec 19, 2007, 01:19 PM
Hit my smoke....
Hostage-46's Avatar
I used a bandsaw, cheap delta tools desktop thing. First I tried clamping in a fence, which is how I rip balsa strips, but the foam can compress and move, I found I could be just as accurate "free hand". I drew a very thin line on the core and just cut it carefully. I practiced with a few strips of scrap foam.
Ulitimately, by the time I finish the spar, it will be wider then the web I cut out. So absolute precision of the cut does not seem to be critical.
The variations in my cut were easily addressed with a sanding block. Similar approach to blocking the ends. When I finish the spar, I suspect I'll need to sand the leading and training pieces to get that final perfect fit within the core.
I considered a wire cut as well, that would be pretty simple, but it seemed like more more hassle given I really don't need it to be perfect.
If you have a bandsaw, go for it, if not use a the wire cutter, either way, press on!!
Discussion How many Mac users are in here? We need a good sim. Gino CP Micro Helis 15 Apr 05, 2007 03:19 PM
Flying in the rain...we need help!! omni99 Parkflyers 9 Jun 05, 2004 10:25 AM
Anyone fly near Bandimere Speedway in Denver? We will be doing some drag racing there Duane Electric Plane Talk 0 Jul 28, 2002 09:34 PM
