1st land sailer - Screaming Reach - RC Groups
Dec 02, 2007, 03:50 PM
Member: GSPL
sloperut's Avatar
Question
Hello, this is my first post in the Sailboat section of RC Groups. I normally spend most of the time in the Sailplane section but I thought I'd try something different that has a wing.
I'll be building this bit by bit so expect updated here-and-there.
Below are photos of the basic frame-up. I need to stop by the hardware store and pick up the metal bits. Then a stop to the local Cabelas for 130# leader for the stays. I'm building per plans.
The plans suggest a sail servo (or high torque normal ) with minimum of 150oz torque. Any suggestions?
Thanks in advance.
Jeff
Last edited by sloperut; Dec 02, 2007 at 05:13 PM. Reason: changed servo requirement in text.
Dec 02, 2007, 05:27 PM
Useful Idiot
If 90 rotation is enough the GWS S04 seems to have a good torque/price ratio.
Dec 02, 2007, 09:43 PM
Originally Posted by sloperut
Hello, this is my first post in the Sailboat section of RC Groups. I normally spend most of the time in the Sailplane section but I thought I'd try something different that has a wing....
Welcome to the world of truly fast sailing, Sloperut. I've long thought that flyers should have a natural affinity for these things. I'm glad to see a report about this design, as it appeared to be well thought out. Is he still selling the plans?
For a description of another wing build, check out this:
http://www.rcsailing.net/forum1/showthread.php?t=3435
...The plans suggest a sail servo (or high torque normal ) with minimum of 150oz torque. Any suggestions?...
I've had good performance with the Futaba S3802
Bill K
http://www.iceboat.org/RCBoats/rc%20boats.htm
Dec 03, 2007, 09:52 AM
Member: GSPL
sloperut's Avatar
Hi Bill, thanks for the greeting. Unfortunatly, Vexa controls does not sell plans anymore and all the info has been removed from the web page.
Martin, thanks for the advice on the GWS servo.
Jeff
Dec 03, 2007, 10:00 AM
doomracing's Avatar
so how did you come across the plans? i'd be interested in a copy.
Dec 03, 2007, 12:37 PM
Member: GSPL
sloperut's Avatar
I bought them about 3 years ago.
Jeff
Dec 28, 2007, 10:07 AM
doomracing's Avatar
i wonder what it would cost to get a copy made at a print shop?
Dec 28, 2007, 07:02 PM
Advert
Doom,
There are some free plans of French origin to be found at the IRCSSA Yahoo forum in the "Files" section. You need to sign on to Yahoo to access them.
http://groups.yahoo.com/group/IRCSSA/
These are the same plans being used by War Bird Radio on this forum at :
https://www.rcgroups.com/forums/showthread.php?t=752215
I think a simple mast with a sail is a better way to go than building a wing
on a first build.
Also, I've been selling plans for my K1 model on eBay at http://tinyurl.com/2lqa7r , with a build log at http://www.rcsailing.net/forum1/blog.php?u=1049
Or build one of your own design, these things can be done pretty simply.
Bill K
Dec 28, 2007, 09:38 PM
doomracing's Avatar
do the plans show how to convert from ice to land application? you using foam aircraft wheels, or in line skate wheels?
Dec 29, 2007, 03:50 PM
I use a 5/16" thick walled aluminum tube for an axle & it can be modified for either wheels or ice runners. Foam airplane wheels (Dave Brown) work great on pavement. I've found inline skate wheels too hard & tend to side slip when windy. If you try them, go for the lowest "durometer" rating you can find, as they will be softer & grip better. There's an entire discussion about wheels at
http://www.rcsailing.net/forum1/showthread.php?t=1800
Dec 29, 2007, 05:15 PM
Not to be rude, but if you're looking for a high torque servo I have a Futaba S3801 here that I don't need, and I'd really appreciate if someone bought it.
It's never been used, still in the box with everything, and I'll give you it for $60.
Dec 29, 2007, 06:34 PM
ballywho-You can buy the same servo at Tower for $54.99 and have a warranty.
Dec 30, 2007, 06:46 AM
doomracing's Avatar
can't blame a guy for trying. servos, and receivers are on my no buy used list. even from a friend.
Dec 30, 2007, 10:48 PM
james carey's Avatar
Hi All , the S3801 sells for around the Aus$100.00 so it's a pretty good deal if you're in Australia .
Sorry mate , I don't need another servo at the moment.
James
Dec 31, 2007, 07:48 PM
Just to get back on topic here, check out the updates to my "Build log" at
Bill K
US 66
