Nov 19, 2007, 02:37 AM
Radical RC Micro Stick - servos
I am building a Micro Stick at the moment and trying to think a few steps ahead and have only built a couple of planes.
So far I have used Hitec HS 50s in my planes and tried to mount them so that my .032 wire runs basically parallel with the bottom of the fuse - in other words the height off the bottom of the fuse at the servo end is what I end up with at the elevator end with as close as I can get to right angles at each end.
It looks as though with a Micro stick the wire would have to slope to the elevator if the HS 50 is taped or glued to the side of the fuse - is this the way to go or should I be looking for a smaller servo with less height. Other thought was to mount the servo upside down so that the arm is just off the bottom of the fuse - this would of course mean not being able to get a screwdriver in to tighten the servo arm when I was happy with the set up.
TD01
Nov 19, 2007, 05:50 AM
Last seen fleeing Detroit
SKYPILEIT's Avatar
servo mounting..
HS-50s will work fine..all it requires is gluing servo to the fuse sides & floor,I wrap the servo in a tiny piece of masking tape first,run the wire back and connect.If its not perfectly parallel to the fuse floor,no prob.You can save weight by making a Z-bend near the servo for adjusting length.This way eliminates EZ-connectors...nothing to come loose & less weight.You will like the micro..I've built 3 of 'em...
Nov 19, 2007, 07:35 PM
Thanks Skypileit for reply - I am in Australia and have a small collection of TD01s so want to try one of those with this plane.
Still a bit confused on the z bend - my z pliers make a neat but fairly small z - are you talking about creating your own z with an ordinary pair of pliers - this would have another benefit here in that the piano wire would then begin to run more in a horizontal fashion rather than on the slope that I first mentioned - the slope from top of the HS50 to the control horn looks like being about 1/2 inch which doesn't look at all right over such a short distance OR are you saying that 1/2 inch slope is ok - no one will see inside the plane but I was thinking more of any strain this might put on the smooth operation of the servo? Normally I have been putting the small Z created with z pliers at the servo end and a Du-bro micro clevis at the elevator end.
TD01
Nov 19, 2007, 07:44 PM
Check my blog-updated
Mayday!Mayday!'s Avatar
The angle won't be a problem in the micro stick. I would suggest the Du-bro micro clevis at the servo ends, it won't be as easy to install at the control horn.
Nov 19, 2007, 08:17 PM
SKYPILEIT's Avatar
Z bends..
Yes,I used an ordinary Z-bend tool....& then both ends are simply bent with needlenose pliers to make a tight U-shape to pass thru the servo or control horn hole.The slight angle of the control wire from servo to elevator is insignificant.The Z portion is then tweaked slightly(with pliers)to increase or shorten the wire for proper final length.
Nov 19, 2007, 09:40 PM
thank you both for the above replies - you've given me plenty of ideas to try.
TD01
Radical RC Micro Stick Building and Flying alligood Parkflyers 937 Jan 14, 2021 09:50 AM
Discussion Help With Radical RC Micro Stick gbeisser Parkflyers 10 May 13, 2009 03:36 AM
Discussion eflite BCX battery in radical rc micro stick noseheavy Parkflyers 1 Jun 03, 2008 12:41 AM
Sold Radical-Rc Micro Stick & Garrison Aerodrome Positron & Todds Models Wing-E Yardbee Aircraft - Electric - Airplanes (FS/W) 7 Nov 08, 2006 11:07 PM
NIB Radical RC Micro Stick kit with motor and props Bud Morrison Aircraft - Electric - Airplanes (FS/W) 4 Sep 26, 2004 11:31 AM
