Nov 08, 2007, 08:28 AM
P. Tritle's Avatar
Build Log
Standard J-1 @ 60"
Well, Here we go into the second "Micro Giant". At 60" span, the J-1 will be giant scale legal, but at a projected flying weight of 24 oz. should be a terrific Park Flyer too.
The Standard J-1, though similar to the Jenny, was a completely different airplane. With it's swept wing and broad gap, the J-1 was reputed to be an excellant training airplane.
The early J-1's were powered by a 100 HP Hall-Scott 4 cylinder inline engine which was reputed to be underpowered and unreliable. Later, a few were equipped with Hispana-Suiza's , and eventually Curtiss OX-5's and OX-6's.
So, with parts and plans in hand, let's get started.
Nov 08, 2007, 08:31 AM
P. Tritle's Avatar
Bowing the Outlines
I like to start the build by getting the bowed outlines layed up so that when framing starts, there's no hold up.
Nov 08, 2007, 08:41 AM
P. Tritle's Avatar
Framing Begins With the Bottom Wing
The bottom wing was done first. Since there's no ailerons the wing goes together quickly. Hard points for the wingtip skids and interplane struts are built into the rib and spar intersections.
The upper and lower wing assemblies will plug into the fuselage, so the aluminum reciever tubes were added at the two root ribs.
PAT
Nov 08, 2007, 09:15 AM
Pat, you're killing me............. :-)
When do you sleep? This obsessive disorder must be addressed & treated. Now I need to go place a nice big order for some more balsa just to try & stay close to your building pace!
This is going to one lovely aircraft. Thanks for all you do for us!
Dale
Nov 08, 2007, 09:21 AM
P. Tritle's Avatar
Dale, Sleep?? What's that??? Only kidding of course. Actually, I just like to watch you guys suffer OK, so I'm kidding again.
Truth is, this one has been on the drawing board for awhile, and I'm just now getting started with the build-- too many interuptions from other more pressing projects. Meanwhile, it's already promised for publication so you'll have some time to get the Jenny together before this one bobs back to the surface.
PAT
Nov 08, 2007, 12:19 PM
Martin Irvine's Avatar
I'll be interested in this one, Pat, as I have had a slightly smaller, (and heavier) version slowly building the past couple of years. It is covered with Polyspan and dope and ready for colour. Must get back to it!
https://www.rcgroups.com/forums/show...ht=Standard+J1
Martin
Nov 08, 2007, 12:25 PM
One cell short of a Pack
steve1814's Avatar
ARRRRGGGGHHH!!!!!!!!!!!!!!!
I'm not finished with my Tritle Spacewalker yet and have "other" Tritles' behind it even!
Well, I am subscribed....count me in on one when when they are ready I think I am going to have a section of my garage solely dedicated to Pat's models....
And to think, I was really debating about ordering the B-17 too!
Nov 08, 2007, 12:54 PM
Veni Vidi Volavi
Brian Allen's Avatar
Pat
Very nice, put me down for one when the time comes. Sigh, just another Pat Tritle design to add to the build list.
Working on the DC-6, going well.
Brian Allen
Veni Vidi Volavi
I came I saw I flew
Nov 09, 2007, 01:27 PM
AmpAce's Avatar
Pat,
Sure glad to see that you are designing some of these old biplanes in the larger sizes. Besides supposedly flying better than some of the smaller ones, they are easier to see, and have more "presence" in the air.
I've been eyeing the Jenny, but will definitely have to have the Standard when it becomes available.
Only problem is, my building has come to a "slowdown", lately, but maybe I'll get on a surge soon, now that winter is coming!
Following this one with interest!
AmpAce
Nov 13, 2007, 09:20 AM
P. Tritle's Avatar
Finishing the wings
Moving on to the top wing, framing is similar to the bottom, but with the addition of the aileron. The rear spar is capped to add a bit of beef for hinging, and the servo box is worked in as an integral part of the interplane strut mount.
Nov 13, 2007, 09:26 AM
P. Tritle's Avatar
The wings are framed and ready to go
The second panel was framed just like the first. The center section was built next, and the whole assembly plugged together. After working on a couple smaller projects for awhile the wing assembly seams HUGE! With all that area, the J-1 should be a real floater.
From here, it's onto the tail section.
PAT
Nov 15, 2007, 11:57 AM
P. Tritle's Avatar
Framing the vertical and horizontal stabs
The rudder and elevator assemblies are together now, just need to finish sand, than it's onto the fuselage.
PAT
Dec 02, 2007, 11:16 AM
P. Tritle's Avatar
Building the Fuselage
The fuselage frames were built and assembled directly over the plans. Machinists squares were used to keep the big pieces nice and square during the assembly process.
Dec 02, 2007, 11:29 AM
P. Tritle's Avatar
Setting up the Motor Mount
The motor mount is set up for the Tower Pro 1000KV Outrunner. The forward fuselage is a bit cramped for space, so the mount is built up first, then the two front formers glued in place. Once that's in, it's back to the tail to add the formers, lower cross pieces and stringers.
PAT
Dec 02, 2007, 12:07 PM
P. Tritle's Avatar
Mounting the motor and servos
The servo rails were glued into the fuselage and the Pull/Pu// cable bellcrank assembly built up and glued in place. The elevator will be driven with a pushrod and the scale cables set up, but won't be functional. The rudder will use cables.
Discussion 2.75oz "Diddle style" Standard J-1 Bipe MISTERSCOTT Scratchbuilt Indoor and Micro Models 4 Dec 23, 2006 02:10 AM
Looking for standard j-1 documentation... silverpoz Scale Kit/Scratch Built 6 May 05, 2006 10:50 AM
Discussion Dumas standard J-1 rays89 Scale Kit/Scratch Built 14 Oct 08, 2002 12:04 AM
F/S 2/3aaa nimh cells $1.60 singlespeed7 Aircraft - Electric - Airplanes (FS/W) 20 Jan 28, 2002 03:00 PM
