A New 1000mm Quad Copter Design - Page 365 - RC Groups
Nov 22, 2011, 10:46 AM
2/3s way to fat, dumb & happy
@Gary - can you buy that material, or do you just cannibalize unweary umbrellas?
Jan 11, 2012, 10:16 AM
I want to build a quadcopter as my college project. I am confused whether to use the gyro-control combo board or separate ones. Please guide me on the advantages and disadvantages of both the ideas. Also since i am new to this, please give me a link where i can find detailed info about the making of a quad.
Jan 11, 2012, 10:26 AM
Tri-Quad-Hexa-Octo-copters!!
Hi,
Start here Quadrocopter and Tricopter Mega Link Index and read the TIPs and Glossary sections and the Beginners Info section links.
Have fun!
Cheers,
Jim
Mar 20, 2012, 10:30 AM
Arrow"s for arms
Originally Posted by jcooksey
The first set is of a curtain rod from lowes bt 1" diameter and bt 16th of an inch thick if that . the second pics is of the aluminum rods they sell . Think these would work for arms?
I used hunting arrows for my arms, buy the good ones that you can change the tips they can be cut to any lenght you mount the motors on the end of the shaft where the arrow tip would go. this is my roll cage that the hood of my car fell on when I was charging the battery.the only damage was one bent arm which took 20 minutes to make and put on the model
Dec 11, 2012, 08:53 PM
Vti 2.4 ghz
Originally Posted by Old Man Mike
Ted,
The Schultze receiver pin spacing looks a bit odd to me. Are you sure they are not the standard three group, 0.1 inch spacing? Maybe they were just bent out a little when you took your measurements. Anyway, here are the photos and dimensions of the Berg receiver include with the PWB (it comes with the single wire modification):
Is it possible to convert The Vti into 2.4 ghz?
Dec 11, 2012, 10:05 PM
va3mw's Avatar
No...
This thread is so old and so many things have changes.
Try looking at the new stuff at www.nghobbies.com
Feb 28, 2013, 05:13 PM
youtube-- orandaboy
Here's a new vid i made with my dji f450 quad
Quadcopter FPV Car Chase (4 min 21 sec)
Jan 12, 2015, 01:39 PM
Gravity always wins !!!
Photo Elevate's Avatar
Spectrolutions flight control board
Anyone still using Spectrolutions flight control board?
I have moved on to other FC's but still have my old board which I might revisit and compare it to modern technology.
Jan 12, 2015, 03:50 PM
Hi P,
Ah the legendary Mike Dammer and Old Man Mike Spectrolutions "Experimental Brushless" DraganFlyer flight controller!... I too have moved on to other flight controllers many times since. I am keeping one DF for historical purposes. I dusted mine off and did a test a couple of years ago and fitted some SimonK flashed ESCs which we did not have at the time. It had rock solid flight and smooth and responsive control. The modern use of accelerometers always trumps the IR self-leveling on the DraganFlyer flight controllers, but the gyro stability is still very good. Multicopter history 101
Cheers,
Jim
Quadrocopter and Tricopter Info Mega Link Index
New Sport Delta own design flying4fun Foamies (Kits) 7 Jun 08, 2004 01:23 AM
New Park Flyer Wing Design John Boren Parkflyers 0 Jul 29, 2003 11:44 PM
New Coroplast Zagi Tray Design mopar_man Foamies (Kits) 10 Sep 12, 2001 09:42 PM
