i bought one of this glue yesterday in krakow, im goin to try it.
maybe they can use this sensor if they have time to write the code, one of my converted esc once behaved strange: it stopped workin (bootin up with the sound was not), i thought soldering or processor fault ,but not, after a while it started to work again, it wasnt be touched for 20 minutes... (i dont want it in the air ![]() but it cant be because of programmed temperature sensing, it was not hot , maybe it was really some touch;| |
Could somebody who knows the conversion routine please point to the hex files and the connection diagram of this ESC? It is a 18A TowerPro.
I really can't find the right one between all the different versions and taking a risk isn't really necessary. What does the calibration option in firmware mean? Thank you very much. ![]() ![]() ![]() |
regards. |
https://www.rcgroups.com/forums/show...&postcount=414 Also the procedure isn't included in the above zip file, or is it? I only found this (complete) one. https://www.rcgroups.com/forums/atta...mentid=2652582 What is the difference on the hex with or without calibration? Do I need to set a calibration byte for these ESC's? Thank you! EDIT: Oke, I have finally found this post by Quax Quote:
The result for calibrated and uncalibrated firmware is the same. |
Although I have read every post in this thread I am still a bit unsure about the exact procedure. Quax advised to used the calibrated firmware when there isn't a external Xtal present. Is this calibration byte already present in the current ESC firmware? And why should the calibration byte not be needed? :? Also this post below from Andrei implies that the picture I have posted above isn't the right one. Unfortunately he has even damaged parts. https://www.rcgroups.com/forums/show...&postcount=499 I have a few days before the conversion so in the mean time I can sort this things out. Ofcourse I would like to thank Quax, Arthur P, Agressiva and all others for your enourmous commitment to make this possible! Thanks! |
The only problem I have right now is about if calibration is needed. But I will probably test it out myself as soon as I have hooked up everything. |
the two versions (with and without calibration) work very well. i prefer the calibrated because all ESC run at same frequency. With uncalibrated version all each esc run in different frequency . This difference is to small but exist. For hobby use this not represent any problem. regards. |
oh sorry, there is really some different on the top, my is like what u linked with the connection, but the circuit should be the same
(https://www.rcgroups.com/forums/atta...hmentid=2652582) |
Thanks guy's. You have helped me a lot. I haven't thought about power output performance of the FET's I uncousciously assumed that the power handling of a FET of that size should roughly be the same. Apparantly there is difference.
Apart from the replaced resistor at the top left corner of the Atmega and at the orange wire there isn't much difference except for signal trace width. ![]() |
I had bad experience converting my TowerPro, so I went another way. See about my conversion here http://forum.mikrokopter.de/topic-11206.html
Hi aggressiva Do you have any more tips for this conversion. I've bought four of these, and converted one. I have followed your picture, in addition I have removed the resistor connected to pad 32 on the MCU, or else it would have interferred with SDA, isn't that correct? (I have tried testing the ESC both with and without this resistor). The programming part is no problem, I can write the fuses, and load the hex. And at bootup, the motor is making the usual bip-bip-bip-biiiip, but there is no response when I send I2c commands from the MK- flight controller. Hope you have any tips, regards -Erik |
Thread Tools | |
Similar Threads | |||||
2 Electro Fusion Motors & CC esc's from Coronas for sale | mthomson | Aircraft - Electric - Airplanes (FS/W) | 7 | Mar 18, 2004 07:13 AM | |
FS- FMA M5 dual conv Rx and 2 esc's- all NIB | Etonic | Aircraft - Electric - Airplanes (FS/W) | 3 | Nov 17, 2003 02:27 PM | |
How do I hook 2 esc's into 1 receiver ? | Al P | Power Systems | 2 | Aug 30, 2002 05:38 PM | |
EBAY Brushless Motor & 2 ESC's | S Anastasio | Aircraft - Electric - Airplanes (FS/W) | 0 | Aug 12, 2002 06:41 AM | |
WTB: 2 Hitec Feather Recievers and 2 ESC's | Ryan Nau | Aircraft - Electric - Airplanes (FS/W) | 6 | Jul 03, 2002 07:13 PM |
