This thread is privately moderated by JimDrew, who may elect to delete unwanted replies.
Dec 21, 2018, 12:28 PM
Originally Posted by AlanDY
Wish I had known that.
On Dec 16 1 8 I sent this message to your Tech Dept.
Gents.
Is the XPS system compatible with the JRXG14 transmitter?
Could I use the X-10 and Nano receivers on all 14 channels?
Alan
The answer I got was. " No, it's not.
Why I am confused???
It looks to me like "the XPS system" being referred to is our radio system. That is not compatible with the JR XG14 transmitter. Our X10+ and X24 are compatible with any of the different serial protocols that they support.
Dec 21, 2018, 12:29 PM
Originally Posted by GEORGE III
Hi Jim,
Any news regarding the JR module used in Taranis.
I understand that Open TX and Companion 2.2 is as yet is incompatible with something, but can't recall why.
Or can we just use 2.2 as we did 2.1.
Have a Merry Christmas and a great year for 2019.
This was fixed long ago. You can use any version of the OpenTx firmware.
Dec 21, 2018, 12:31 PM
The R10DS receiver supplied with the RadioLink 12 channel transmitter has a Port (If that is the right word) that is a labelled " SBUS signal."
Does that mean that any of the XPS products could work using that?
Only the following products would work: X10+ and X24. None of the XtremeLink radio system products would work with it.
Dec 24, 2018, 10:11 AM
Ok so If I connect an X-10 to the SBUS outlet on that receiver could I use a Nano as a second receiver?
if so, how would I do that, where to plug in the nano and how to bind it to the X-10
Thanks and a Happy Christmas and a Healthy New year to you and all my unknown friends who help me understand what goes on with your products.
Dec 24, 2018, 10:42 PM
IF you are using ALL XtremeLink products (transmitter module and receivers), then you can use a Nano with any other XtremeLink receiver. You can not mix and match brands of radio systems.
Dec 25, 2018, 09:40 AM
Thsnks, I was afraid that was the case
May 10, 2019, 04:10 PM
Any one know if the new Jumper T16 will work with an Xps JR module? Looking at new radios and this looks interesting.
Heather
May 11, 2019, 01:35 AM
It doesn't have a removable JR or Futaba module port (as far as I know).
May 11, 2019, 04:12 PM
It does have a JR module port.
See this review.... https://oscarliang.com/jumper-t16-radio/
May 11, 2019, 07:46 PM
Smyk's Avatar
Seems like PPM mode will do with Jim's JR module
May 12, 2019, 06:45 PM
Yeah, that's not the same jumper transmitter I have seen.
May 25, 2019, 03:09 AM
Well I have my Jumper T16 TX and XPS JR module now.
It works using PPM but could not get it to work with XJT D16. Am I missing anything by using PPM instead of XJT?
(My JR Module is v4.3 and I did change it to the XJT input mode)
Heather
May 25, 2019, 03:20 AM
XJTD16 supports 16 channels. PPM spec is only 8 channels, but the module should be able to support up to 16 channels if the frames were long enough.
What does the LED on the transmitter module do when you have the input mode set to 2 flashes (XJTD16) and you have the transmitter set to use XJTD16?
May 25, 2019, 04:05 PM
In XJT mode the module led is solid red. PPM mode does seem to allow up to 16 channels with a frame length of about 38ms.
May 25, 2019, 06:12 PM
Well, red LED means that the protocol is not valid. So, perhaps it is not exactly correct? I am glad to see that 16 channels in PPM mode works. I have never tested that before. 38ms is still faster than any PCM system.
Heli Radio Needed What are your sudgestions? rspiegel Electric Heli Talk 14 Sep 13, 2002 01:00 PM
What pitch are the gears in the Great Planes GB? slowflyer Sport Planes 1 Oct 04, 2001 10:27 PM
What cells are you using in your Sokols? Jensst High Performance 10 Jul 13, 2001 08:43 AM
Hitec radio systems...how good are they? luv2fly Electric Sailplanes 6 Apr 24, 2001 01:49 PM
