Nov 29, 2002, 08:52 PM
How do i put the brake on my Jeti ESC
I have a Jeti 40AMP ESC and i cannot find my instructions Can anyone help me?????
Fuzz
Nov 29, 2002, 09:59 PM
KLH
KLH
Pack Rat
KLH's Avatar
JETI Break
If it's their ESC for a brushed motor it's just the little jumper on the end of the ESC, The brake is off when the jumper is placed on the pins and the brake is on when the jumper is removed.
If it's their brushless ESC it comes with the brake activated. If you want to turn the brake off do the following:
1. Switch on your TX and move the stick to full throttle,
2. Connect the battery pack to the ESC and turn on the switch if you use one
3. Wait 5 seconds (it seems like forever)
4. After 5 seconds you should hear 4 little beeps
5. As soon as the four beeps sound bring the throttle quickly back to the stop/closed postion.
6. You should hear 2 beeps, which means the brake is turned off.
To reactivate the brake just repeat the above.
When the brake is active and you turn the ESC on you will hear 1 beep, when the brake is inactive and you turn on the ESC you will hear 2 beeps. Hope that helps.
Kern
Nov 30, 2002, 12:53 AM
kushal_22's Avatar
It helps me a bunch too.
Kush
