Aug 21, 2007, 08:19 PM
jrotor's Avatar
Question
Beginner needs help. World Model Piper Cub(1/6 scale) conversion.
Hi
I have a WM Piper cub and here's the spec on the box.
[/B]
Wing Span : 71.0 in / 1800 mm
Wing Area : 698 sq in / 45.0 sq dm
Flying Weight : 5.5 lbs / 2500 g
Fuselage Length : 47.0 in / 1200 mm
Engine Required : 2C 0.40 cu in : 4C 0.52 cu in
Required : 4 channels, 5 servos [/B]
Here what I currently have.
Four packs of 3S1P 2100mA 15C Lipo battery.
Castle creation 55A ESC and 5ch receiver.
So, I guess I need to buy a motor and may be battery.
Please advice me what motor and battery I should get from United Hobbies.
I don't want to overpower but good enough for big loops.
If I can get around 10,000 RPM with 11x6, I'd be happy.
Thank you for your advice.
Aug 21, 2007, 08:54 PM
E-flyer since 1981
Michael in Toronto's Avatar
I think the 3S batteries are your limiting factor. 4s would be better for a 5.5lbs model.
Anyway, I think an AXI 2826-10 (whatever the United Hobbies equivalent is) on 2 of your packs (in parallel for 4200 mah) with a 13/6 prop would fly the plane OK, bit probably would have trouble doing a loop.
I don't know much about United Hobbies; maybe someone else knows the equivalent motor.
Aug 21, 2007, 10:48 PM
jrotor's Avatar
Ok, what setup should I go in order to achieve loops ?
For Sale LOCAL PICKUP(San Jose, CA) :: World Models Piper J-3 Cub 1/6 Scale ARF jrotor Aircraft - Electric - Airplanes (FS/W) 0 Jul 08, 2007 04:29 PM
Question Any tips on biulding a 1/6 scale piper cub kit? bouncy-boy Scale Kit/Scratch Built 3 Apr 11, 2007 02:51 PM
Sig J-3 Piper Cub 1/6 Scale kit BrianRickman Aircraft - Electric - Airplanes (FS/W) 2 Aug 19, 2003 06:12 AM
Sig Piper J3 1/6 scale jstanton Scale Kit/Scratch Built 2 Nov 14, 2002 09:48 AM
1/6 scale SIG CUB...will it fly? Graeme Fuel Plane Talk 3 Jul 11, 2002 03:48 PM
