6" F-18 hornet
Hi,
A year ago I was experimenting with a 6" F-18 Hornet, but I abandoned that project because I had some range problems with my IR setup. Now that I've been enhancing my IR setup, I took up that project again and made a new 6" F18 Hornet with some lessons learned from my previous experiments. Here are some specs:
I tested it at dusk - because there was almost no wind - and it seems to fly. I can steer left and right and it keeps aloft at a bit more then 1/2 throttle. I have to steer it very gently though, as it can easily get into a spiral. However, I have the impression that it is rather stable in flight. Real tests will be conducted once the indoor season starts again in October ;-) For trimming I put both motors at the same distance from the fuse. Both motors induce a drift to the right. So I let the prop at the right point down and the prop at the left point up. This will cause a upward thrust vector at the right side and a vertical downward thrust at the left side. This seems to be sufficient to compensate for the motor torque... Some pictures below. regards, Johan ImagesView all Images in thread
Why did you choose the 18 ohm motors? Do they provide more thrust than the 10 ohm motors?
Good, that is what I was hoping when I ordered them the other night.
BTW, I ordered some upgraded tail props for the ITC Micro Mosquito, they look very much like the PiccooZ props, but you can actually buy them as a part (not cheap though). Once they get in and I have a chance to try them, a review will show up in here https://www.rcgroups.com/forums/showthread.php?t=728851 or in a separate thread. |
Dude, nice work! Try this one in that scale.
F-4, 10 in long, 7 in wing span. AUW 14.6 g. Differental thrust. |
Thread Tools | |
Similar Threads | |||||
KC F/A-18 Hornet (Bug) | Tomcat Driver | Electric Ducted Fan Jet Talk | 367 | Feb 25, 2010 06:23 AM | |
2 Seater F-18 Hornet Canopies... | gbruce | Electric Ducted Fan Jet Talk | 8 | Oct 06, 2003 01:39 AM | |
F-18 A Hornet | christopher2 | Electric Ducted Fan Jet Talk | 1 | Jun 07, 2003 03:27 PM | |
F/A-18 Hornet Plan Built | daladiesman | Electric Ducted Fan Jet Talk | 1 | Oct 29, 2002 11:40 PM |
