May 12, 2001, 12:18 AM
Permanently banned
Mario's Avatar
MIA - Hornet Upgrades
Hornet Upgrades:
Metal Main Shaft $4.99
Alum Pinion Gear $6.49
New! - Anti-Rotation Upgrade Kit $14.99 :
1) Alum Shaft Collar with set screw
1) Alum "Possitive Lock" anti-rotation dual arm with set screw. Note this was previously $9.99 but the anti-rotation arm has been improved, it is now double winged for higher precisionand has been CNC machined.
1) Hex Key Tool supplied.
Molded Tail Servo Mount Plate Upgrade $2.49
This part mounts directly and precisely on the boom. Makes servo Installation a snap.
Mario www.micro-flight.com/newframe1.htm
[This message has been edited by Mario (edited 05-12-2001).]
May 12, 2001, 12:56 AM
Sounds nice Mario. Do you have any pictures, and what sort of delivery time are we looking at?
Regards,
Trevor.
May 12, 2001, 06:54 PM
Permanently banned
Mario's Avatar
Parts are in stock. 2-3 day if you want priority shipping.
Mario
May 12, 2001, 07:42 PM
Thankyou, an e-mail is on its way.
Trevor
May 12, 2001, 08:43 PM
Mario;
Could you post pics with Hornet before and after modifications?
Thanks!
May 14, 2001, 06:08 AM
Permanently banned
Mario's Avatar
CNC machined aluminum Parts:
Anti-Rotation Positive locking double wing arm and shaft retainer collar kit.
Installed Anti-rotation wing and shaft retatiner collar.
[This message has been edited by Mario (edited 05-14-2001).]
May 14, 2001, 02:39 PM
Hello Hornet owners,
I just received all the upgrades listed above and they work perfectly.
Highly recommended!
Thanks Mario
Glen
May 14, 2001, 11:59 PM
jk
jk
jk's Avatar
mario,
is your ally gear a .4 modul pitch?
ps. the parts look nice!
May 15, 2001, 01:28 AM
"Watch this!" SMACK!
jaggies's Avatar
Just got mine today. Very speedy delivery. Looks real clean. Can't wait to fly with it!
--jim
May 15, 2001, 09:02 PM
Permanently banned
Mario's Avatar
Alum Gear Pitch: is 64P.
Servo Mount Plate: is a simple injection molded part that is concave on one side and flat on the other side. You can mount the servo plate with a strip of industrial double sided tape supplied, any way, on the boom's side, top or bottom near the rea of the frame. Servo and gyro both can be attached to this mount at 90 degrees with each other or in saddle like fashion if you use two servo mounting plates opposite each other.
Mario
May 16, 2001, 02:37 AM
jk
jk
jk's Avatar
Mario,
i got one of your MIA ally 10T pinions for my piccolo awhile ago and tested it. it worked ok but i think the piccolo's pitch is a bit coarser at .5 modul.
whereas it works perfect on the hornet whose pitch is .4 modul. so it must be that .4 modul equals 64P?
your comments on this?
May 16, 2001, 01:43 PM
Permanently banned
Mario's Avatar
We have just sold the last batch of alum pinions and are temporarily out of them.
More available to ship in two weeks. Sorry about this but they have been selling faster than we expected.
However, we are still taking backorders if you want to order the alum pinion gears along with other upgrade items which are in stock ready to ship.
Thank You.
Mario
[This message has been edited by Mario (edited 05-16-2001).]
May 16, 2001, 01:56 PM
jk
jk
jk's Avatar
thanks for the info mario!
May 16, 2001, 04:26 PM
Our Daddy and Heli Junkie
Fred Bronk's Avatar
Mario, lloks like I will be joining the ranks of the Hornet owners?
Since I have not recieved the kit yet, what mods do you (or anyone else!) recommend if I can already fly a heli?
May 16, 2001, 08:39 PM
jaggies's Avatar
I've had my Hornet for about a month now and am very happy with it.
The Hornet flies pretty well as-is. You might consider a metal mainshaft, as that appears to be the Achilles heel.
I found most of the mods on Brad's site useful:
http://www.alcita.com/bkg/hornet/
Beware of the rubber stopper on the main shaft though. I've had some near mishaps when the stopper slipped. I now fly with a small drop of CA to hold the plastic stopper and the rubber tube to back it up.
One other mod I'd add is to insert washers to center the flybar control arm such that the pushrods are centered in the head. Otherwise the flybar teetering will be asymmetric (or at least it was on mine).
--jim
