2.4Ghz banned in Belgium
Hi,
Decision just fel today August 3rd 2007 : The Belgian Institute for Post and Telecomunications is banning the 2.4Ghz for all RC-applications. (French link : http://www.rcpilot-online.com/index....dee8b56c582cf2) (Duch link : http://www.modelbouwforum.nl/phpBB2/...62558&start=15) This decision is taken due to the fact that the use of this frequency-band by the modellers is not described in the European texts (laws?). It seems that a recent demand has been applied for that but still not agreed for. It also seems that in Germany some problems are arrizing with official authorizations... Just found this too : In Germany, the „Bundesnetzagentur" (organisation of the state) informed that 2,4 GHz RC equipments for aeromodelling will not be allowed. The decree will come to power in July 2008. Radio Control of model aircrafts using this frequency band competes with commercial and political interests mainly because of the strength of the transmitter signal which is necessary to overcome physical disadvantages of the very short waves. from here : http://www.rcpilot-online.com/index....705&paa=1&zaa= To be followed... Olivier my website : http://users.belgacom.net/TX2TX : buddy box compatibility problems between different brands of transmitters |
Not true for Germany - on 31. July 2008 version 1.71 of the EN 300328 will go into effect replacing the previous version 1.61. There is a new statement in v1.71 stating:
"Equipment uses a medium access protocol designed to facilitate spectrum sharing with other devices in the wireless network." This is interpreted by the BNA (Bundesnetzagentur) in two ways: - Some systems (most notably SpektrumRC and spektrum-based systems like JR) bind to fixed frequencies at startup and staying there so these are not allowed anymore. - The BNA thinks that EN 300328 only applies to 'networks'. (whatever that is) Personally I have doubts that the second point holds water. Right above this sentence in the scope of EN300328 the regulation explicitly allows for adhoc systems and the norm does not define any needed infrastrucuture. The most simple form a 'network' are two devices and the regulation does not limit the applications using 2.4 Ghz at all. Even in the worst case this ban is only limiting future sales of such equipment. 2.4 Ghz rc control equipment already in the hands of the end user and in use under EN 300328 v1.61 will not be affected and may be used on. (Source: DMFV: http://www.dmfv.de/pages/funk/2,4%20GHz%20Anlagen.htm ) I suggest you ask the Belgian IPT two questions: - if this ban of remote control applications also applies for industry controls? Quite some habour and construction equipment is run today over 2.4 Ghz remote controls. - if industrial 2.4 Ghz process sensor networks and process controls are banned either? Quite some industrial control jobs are done today over 2.4 Ghz (WLAN or BT): e.g. http://www.schildknecht.info/?navi_id=12&content_id=13 If they are banning these remote control applications too I am sure the Belgian industry will not approve. Regards Frank |
There are certainly some odd "conclusions" there. It would appear that the Spektrum meets the needs to form "add hoc" networks by searching for clear air before coming up. "Channel" hoppers like Futabe seems to
just stamp on the whole band -but not for long. However, the Futabe also FCC qualified its Tx in a receive mode - so what is the real story. Enquiring minds need to know ![]() |
The whole issue is still kind of muddy, unfortunately.
To meet the spec of the new EN 300328 (after 31. July 2008 in effect in the whole EU) a device must "share" the spectrum during runtime (hop away in case it finds its band suddenly used or hop away all the time), so I was told. Also all 2.4 Ghz rc controls are certified and sold as 'WLAN' equipment here. This seems to be also reason of problems when regulatory bodies decide that it does not fit in their bureaucratic view of the wireless world. (As you can see in Belgium now) Futaba FAAST indeed scans the 2.4 Ghz band at TX startup. You can easily test this by running a Bluetooth device like a headset or wireless speakers (A2DP protocol) with heavy BT traffic right beside the FAAST TX. It will then take much longer to go online and the leds on the backside of the T6EX are flashing quite a while before the link is established. I suspect that FAAST scans the band, to make sure the remaining bandwidth is sufficient for the wireless link. Maybe it even does something more sophisticated by checking which parts of the spectrum are congested and limiting the hopping to the unused parts, telling the RX in some control packets. Regards Frank |
I thought the FCC (USA obviously) disallowed a selection of frequencies on 'hoppers'. In other words you hop everywhere or not at all. |
"To meet the spec of the new EN 300328 (after 31. July 2008 in effect in the whole EU) a device must "share" the spectrum during runtime (hop away in case it finds its band suddenly used or hop away all the time), so I was told."
Which would result in "might is right" since the current user would be required to move away from the next guy to come on? Does this sound crazy or what? |
![]() ![]() What then are the Mexicans south of you? |
There are HERE! ![]() Crash P.S. Planning on two JR 9303 2.4GHz TX with lots of rx's for Xmas. Why 2? My partner in crime (15 yr old son) has made it very clear he gets a 9 channel (for his hotliner) before I do! ![]() |
Besides that, you can just pay the fine to the Policia on the spot and be done with it ![]() |
For all those guys here in Belgium, we'll have to wait on what is going to be decided on the next CEPT meeting on the 31th of March and April the 1st
see: http://www.flytovml.com/flytovml/ Still crossing my fingers and otherwise I'm moving to the states ![]() |
Thread Tools | |
Similar Threads | |||||
Question | E-flite 2.4ghz RX in a sabre with DX7 TX | p4ddy | Micro Helis | 6 | Jun 11, 2007 03:24 PM |
Discussion | Carbon and DX7 (or 2.4Ghz in general) | Raphael | Radios | 52 | Apr 11, 2007 06:02 PM |
Discussion | DX7 and 2.4ghz /4-in-1 Control Unit, Rx/ESC/Mixer/Gyro :BCX2 | air365 | Micro Helis | 2 | Apr 05, 2007 10:48 PM |
New Product | Sony 6.5" Built-in 2.4Ghz Wireless AV Receiver | flyn325 | Aerial Photography | 1 | Dec 26, 2006 06:29 PM |
High Speed Miniature Tranceivers - 2.4GHz with Built-In Antenna | CrashingDutchman | Scratchbuilt Indoor and Micro Models | 1 | Apr 12, 2005 09:36 PM |
