Yippee!
This pod came out so good I just had to post those photos!!
For those of you who don't know me and Dima (Dimson) are building an SG-II with some small modifications... one of them is the pod - I will build it to similar to the "Arrow" pod just because I think it is stiffer and much more sexier than the original SG pod.
I have done the mould several months ago, and since then I tried several layups and techniques to try and get the best pod I can. Most of them weight around 16 gr, but this time I wanted to make it stiffer and see how much weight it will gain... So I added another 0.4 mm UD carbon reinforcement and another 120 gr/sq.m carbon patch under the wing. It added only 2 grams, so now it weights only 18 gr and it is very stiff, all I have left to do now is to trim it a bit. P.S this the most good looking pod I made ever! ![]() ![]() ![]() See for yourselves Eitan. ImagesView all Images in thread
Very nice job Eitan,
I am an experienced mold maker and have made molds of many products (although never a model airplane part) and I must say you have acheived excellent results. How did you determine the wing incidence and what airfoil is the pod built for? Again, excellent job. Cheers, Paul |
Ahhhhh....
Shiny Pretty Nice lines What does it weigh? |
Nice looking pod!!!
Ed Intheswamp |
First layer is 4.3oz carbon Then you have some UD carbon reinforcements through the entire length of the pod and some cross UD reinforcements in the wing area And in the front area you have the 2.2oz kevlar Quote:
Me and Eitan are going to build the SGII together and we should get the wing cores CNC cut in the upcoming days. Then you can expect some building action in the SGII building thread ![]() |
Impressive! That's the lightest carbon fuse I've heard of to date.
Nice work Eitan!!!What resin???
Thanks for the kind replies
![]() I will answer your questions one at a time: thermalking I'll try to make this as clear as possible. First layer - ~4.3 oz carbon fabric all over the mold Second layer - 0.4 mm thick UD carbon 1 cm width on the entire length of the pod, and another small UD patch on the area where the boom ends all the to about 1" in front of the wing LE. Third layer - 2.2 oz Kevlar on the front of the pod (as seen in the first picture above), and another small patch of 4.3 oz carbon on the area under the wing. Fifth layer - pill ply for glue-able area after the resin is cured (this layer is piled after vacuum). flxzcat I make mold a living as well, and all of them are for bigger model airplanes ![]() ![]() the pod is built for the SG-II airfoils which means the it is set for the AG airfoil, I have done this by making a wing and cutting the center of it and glued it to the master, you can this entire process in the mold build thread I have done several months ago. Mold build thread Jim Walker It weights around 18 gr before trimming the wing area. dougmontgomery I used a Ciba 5052 Epoxy, this is a very toxic resin and when I work with it I use gloves (change them every 10-15 minutes) and a 3M gas mask like this one: ![]() sporter You have no idea how right you are! Hope I have answered all of your questions, and if you have more please don't hesitate to ask! Eitan. |
Thread Tools | |
Similar Threads | |||||
Discussion | Maiden didn't turn out so good (humor) | steve1814 | Scale Kit/Scratch Built | 4 | Apr 03, 2007 03:00 PM |
Discussion | It Was Cheap but Came out Looking Good. | Boss248 | 3D Flying | 25 | Mar 29, 2007 06:21 AM |
Discussion | This one turned out pretty good | kun114 | Motorcycles | 6 | Aug 13, 2006 09:16 AM |
Free Hand Plans...this Is What Came Out Of It. | snolord1 | Electric Ducted Fan Jet Talk | 2 | Apr 17, 2005 02:22 PM | |
I just had to post pics of this one | errolw98 | 3D Flying | 15 | Feb 18, 2005 10:18 PM |
