Blue Arrow Venus DLG - RC Groups
Jul 25, 2007, 02:07 PM
Idle up!
PLATINUM's Avatar
http://www.ltair.com:81/en/detailproduct.php?intID=156
post this a while back.. was wondering if by now people had seen this pop up at any stores. Looks better than the older version.
Jul 26, 2007, 03:43 AM
I got one about week ago.
Servos were already installed so only had to mount horns and connect pushrods. Quick and easy.
Have flown it only couple times cause weather in here has been kinda s**tty.
For it's price I like it a lot.
Weight with 4x1000mAh nimh-battery (yeah I know... ) is about 235g. Though with that battery no need for lead in nose to fix cg.
I believe the recommended cg position is a bit forward. As this is my first dlg it's ok for now.
Need to install lipo and ubec for receiver later today.
-Samu
Jul 26, 2007, 11:00 AM
Looks really cool Ippe. Where did you get it and what was the price?
-Stephen
Jul 26, 2007, 11:04 AM
kimhey's Avatar
Is it just me, or does that throwingpeg look flimsy? I have the smaller version, and had to redo the peginstallation. No problem since.
Could you weigh the wing and give a feedback? If servos are already installed, please state what kind you are using.
Kim
Jul 26, 2007, 02:09 PM
Idle up!
PLATINUM's Avatar
Ya.. i'd like to know pricing etc.. as well.
Jul 27, 2007, 04:41 AM
Well hello again..
Throwpeg is the one that came along with glider. I just added a bit of epoxy to fasten it. Now I have done ~30 launches with it and it seems to work fine.
In the attached pic you can see fiberglass strip added to underside of wing to strenghten throwpeg area.
I'll weigh parts separately later today and post results then.
It was attached with 4 servos. I believe all of them are Blue arrow 3.6g.
Bought it from Finnish hobbystore. Price was about 70.
Jul 27, 2007, 02:27 PM
Weights (scale accuracy 2 grams):
left winghalf 52g
right wing 52g
fuselage excluding battery 74g
Jul 30, 2007, 07:21 AM
Idle up!
PLATINUM's Avatar
How has it flown Ippe?
Sep 20, 2007, 07:56 PM
Hello everyone, www.ltair.com is the webiste of BlueArrow, please feel free to visit, you would find a great surprise.;-)
Oct 22, 2007, 08:14 AM
hi does any one know were to get the venus glider in aus or how i can get prices if any one can help pls contact me on bradley_r1@hotmail.com
Oct 22, 2007, 03:29 PM
Ippe- just a question. I'm building a SPIN DLG and most DLG's have much shorter servo arms. Seems you would have to dial out a lot of throw, losing resolution at the TX. Just wondering about that ,maybe it makes no difference at all. BTW, thats a great looking sailplane.
Oct 23, 2007, 01:16 PM
Frans Bal's Avatar
Hello all,
It seems that there are a few versions of the Venus.
The Venus Ippe bought has a wooden fuselage with transparent wing covering.
A member of our club bought one with a wooden fuselage and yellow wing covering.
Nothing special here, but his boom was way to flexible. After one hour of throwing it snapped in two what resulted in a total write-off.
At this moment WWW.F3K.nl, the Dutch DLG website, is testing the Venus. http://www.f3k.nl/pages/venuspag.html
This Venus has a fiberglas fuselage and sturdy boom.
First it was tested in standard configuration, straight out of the box.
Maximum 30 to 40 sec flying time from a height of 30 meters.
After some modifications the time more than doubled and the Venus was much easier to fly.
The last tree pictures show the modifications.
-1- Rounded wingtip
-2- Larger vertical stabilizer
-3- Changed the steel pushrods to single-pull (weight reduction)
-4- More dihedral (don't know for sure)
Frans
Oct 23, 2007, 03:10 PM
Devine's Avatar
The modifications are:
1. Rounded the wingtips
2. Larger vertical stabilizer (improved the startheight up to 7 meters)
3. Changed the steel pushrods to single pull
4. More dihedral. (there wasn't any)
5. No Ailerons. I removed the servo's en fixed the ailerons with tape.
The weight is reduced from 250 to 222 gram and all the changes are a great improvement.
The average flightimes doubled and now its a joy to fly this plane.
grtz
F3K Netherlands
Oct 23, 2007, 10:40 PM
hi were can you get this model in australia? (venus)
i cant seem to fin d it any were help pls !
Jan 20, 2008, 06:03 PM
Is it available in US?
Discussion Blue Arrow Angel ***DLG*** rdaggett77 Hand Launch 55 Jun 24, 2014 01:20 PM
Blue Arrow Micro Servos, RX, and ESC Vanilla Scratchbuilt Indoor and Micro Models 95 Aug 02, 2007 08:58 AM
Question Blue Arrow Angel DLG helipilot Hand Launch 5 Jul 23, 2007 02:23 PM
Wanted Blue Arrow: Venus DLG PLATINUM Aircraft - Sailplanes (FS/W) 0 May 27, 2007 10:59 AM
Blue Arrow 4.3g servos? Dave K Parkflyers 6 Oct 15, 2004 06:30 PM
