This thread is privately moderated by Jack Crossfire, who may elect to delete unwanted replies.
Jul 22, 2007, 11:06 PM
Jack Crossfire's Avatar
First daylight for the Canon TX1
First flight for the Canon TX1 (4 min 3 sec)
So after 5 hours of preparation, finally got the first daylight HD in. What really stands out is the Canon's high shutter speed. Blades appear to spin backward. The copter is always sharp.
At high shutter speeds the 1/2.5" CCD's all bloom when shooting white objects in front of dark backgrounds. The solution is to use low shutter speeds and stop down, but the Canon doesn't have manual shutter speed for video. It uses the highest shutter speed possible.
The Sanyo HD2 has manual shutter speed, so it wouldn't have this problem.
For the Canon's first coverage, had upgraded PWM code and a new 3.3Ah battery. Got 15 min before wind became impossible to take off in without flipping over. The ESC wouldn't work with the PWM at 60Hz. Needed 75Hz.
Notice the yaw oscillation. The PID loop must be recalibrated for the new PWM period.
Jul 23, 2007, 12:27 PM
Real Time Recon
realtimerecon's Avatar
Jack...Overall how do u like the TX-1 ?And have u had it in the air yet? thanks
Jul 23, 2007, 02:55 PM
I have used both cameras. This is from a quality
standpoint. Your opinion may rely more on usability
which I have no opinion on. This was the first Canon
I ever saw which had lower quality output than its competitors.
Would have probably gotten the Sanyo, based on 1 month of usage.
Canon TX-1
convenient mounting
cheapest HD cam with zoom
best stabilization
no macroblocking in fast motion
mosquito artifacts
heavy 9oz
blurry lens
no manual shutter for video
lousy color in bright light because of high shutter speed
\exposure lock for video doesn't work
Sanyo HD2
sharp lens
better color in bright light because of ND filter
long recording time
light 8oz
smarter autofocus
30% more expensive
macroblocking artifacts in fast motion
inconvenient mounting
lens cap falls off
no exposure lock
lousy stabilization
Jul 24, 2007, 12:04 PM
Real Time Recon
Thanks much for feed back jack.
Jul 24, 2007, 12:19 PM
Real Time Recon
Jack...pcworld.com gives the sanyo HD-2 apoor rating,w/only 1out of 5 stars,and tons of reports.
Jul 24, 2007, 02:12 PM
As a consumer, you won't get good quality from either camera. You still have to be intimately involved in the quirks of the autofocus, shutter speed, f-stop, iso, ND filter to get anywhere with these cameras. Consumers should stick to the low definition pencams for a bit longer.
any first flight for a TM scream-n-leap Parkflyers 3 May 04, 2002 04:50 PM
first mod for stick ??? jeffhines Parkflyers 1 Feb 04, 2002 08:36 AM
First flights for me and my Dusk Stik beagle92 Parkflyers 9 Jan 03, 2002 09:24 PM
First Flight for E3D, how are the Control Throws? kenny_dilger Sport Planes 19 Dec 17, 2001 04:21 PM
