Jul 10, 2007, 07:37 PM
hawaiianspork226's Avatar
Build Log
VT flying wing thing
so i havent built anything in a while and i was jonesing for a new, quicker build before i got locked in on a new never ending large project
i had been drawing these types of configurations for a while and since i was tired of usual conventional aircraft, went with a wing
the general configuration is pretty much like a stryker/funjet type layout, though i have not yet decided on 1 or 2 verticals, canted or no, etc; maybe even tiplets...
the major twist on this build is that im gonna install a single plane thrust vectoring sytem on it, just to see what it does not gonna lie; the ultimate goal is backflips (or frontflips) within its own length
of course ill get it flying pretty before i activate the VT mix, just to make sure its a viable airframe first
not looking for ballistic speed, doesnt even need to be fast really... just rediculously agile hehe
data so far:
span: 40"
length:34
wing area: 450 square inches
primary building material: protection board (?)... the new FFF
spars: spruce so far
motor: E-Flite six series 2700kv; unless somebody has a better idea thatll turn
a 5 to 8 inch prop... most likely an apc e 6x4
prop: prolly an APC E 6x4
batt: 3s 2000-ish mah
servos:HS 65's on elevons... something bigger (HS 81?) on VT
ill try and get a scan of the basic 3-view and post it here
so far i have completed the outboard wing panels and the inboard wing panels. tonight im fleshing out the details of the internal supports and structure to make sure it can stand up to the VT system as well as some pretty stressful flight loads.
been thinking about names... maybe ill wait to see if it flies lol... dont wanna waste a good name lol
-David
Jul 10, 2007, 09:28 PM
pics
k so i borrowed my roomates camera
forgot to mention also that the ailerons will be made out of 2" balsa aileron stock
the inner wing root sections still need joiner ribs and some more structural reinforcement, but you get the idea
the nose/cockpit area will be made in 2 halves out of 1.5" blue foam, with a cavity cut out for the battery compartment
-David
Jul 10, 2007, 09:49 PM
↓↘→ + (punch)
theKM's Avatar
that's rock'n!
...looking forward to seeing the rest of it
Jul 10, 2007, 09:51 PM
Use whatcha got!
msmith's Avatar
Yurp... Speaking up to say I likey, and to subscribe!
-ms
Jul 10, 2007, 11:15 PM
HappySpringPerson
youth must fly's Avatar
David very impressive!!!
Jul 10, 2007, 11:19 PM
3D-Flyer Kevin's Avatar
Sweet
Kevin
Jul 11, 2007, 08:15 AM
last night i finished the spar halves, though i hevent rejoined them yet
i also made a second, "aft" spar out of 2 layers of FFF sandwiching a 1/32" ply layer. the motor mount structure will tie into this, and this spar will in tun tie into the rejoined spar... so hopefully the hole thing will end up fairly strong
still pondering the vertical surface question; 1, 2... 3? i dunno yet; maybe even some bottom vertical surfaces too in order to increase stability in high alpha maneuvers
-David
Jul 11, 2007, 10:37 AM
I would use 2 vertical surfaces on the wingtips providing that they are not at any angle besides straight
Kevin
Jul 11, 2007, 11:32 AM
thermal's Avatar
Great project! I've been toying with a vectored thrust idea too, I also want to do flips in the planes own length.
Bob
Jul 11, 2007, 06:03 PM
got the aileron stock and some foamsafe CA today at work; good to go
tiplets huh? i know they would work the best; provided i mount them straight... so maybe ill make them removeable in case i want to install inboard verticals... still thinking
-david
Jul 11, 2007, 07:09 PM
EvanTheDestroyer's Avatar
Awsome Design
Can't wait to see the results
Jul 11, 2007, 07:38 PM
thanks
update:
so weve got the e-flite six series at the store, and thats $80; weve also got the himaxx 2825-2700 at the store, which is also $80
the himaxx is heavier but more powerful...
heres my explanation for why i need more power... i think
the VT system requires one more servo; and a strong, heavy one at that. i want at least one to one thrust so i was thinking with the added weight of the VT that i would need more power
any other ideas for beefy powerplants???
-David
Jul 12, 2007, 12:17 AM
finished the spar "box" assembly; kinda stuck for now till i get the hinge system for the motor all figured out.
i think im gonna use a clamshell mount for the motor, that being bolted to either aluminum or plywood "ears", which in turn have piano hinges (preferably metal or really strong composite) attached to them, and those then bolted to the back of the aircraft in a very beefy mount
ive got a test this week so probably no more progress till friday night or maybe saterday
-David
Jul 12, 2007, 12:30 AM
Fly by grace
rkhoo's Avatar
May I ask which foam-safe CA you are using ?
Jul 12, 2007, 12:19 PM
Retired CAD guy
birdofplay's Avatar
Here is a Line Drawing that I did of your design in CAD.
this is a screen capture.
CAD ver available , just ask :-)
I assume that you designed IN some TIP washout.
Now tell us how you managed to do the LE bending ?
That will determine the radius.
It appears that you may have simply folded them,
maybe with a backside crease ?
What meterial and thickness are you using?
Thanks for the design
Discussion Anyone familiar with the Wing Thing or So Slo flying wings? willin Flying Wings 2 Dec 08, 2006 08:11 AM
Looking for a flying-wing kinda thing. windsurfer Foamies (Kits) 39 Dec 18, 2004 08:58 PM
Flying wing-thing flies! (but questions!) DaleM Flying Wings 6 Aug 21, 2004 04:30 PM
Hey Guys Check this out!!!!!! The Wing Thing is Awesome!! JStory Electric Plane Talk 44 Jul 26, 2001 03:07 PM
Where Can i find the "Wing Thing" Kit or Plans that are in .jpeg JStory Electric Plane Talk 1 Jun 26, 2001 09:50 PM
