Jul 09, 2007, 06:35 PM
Team Extreme! Team Twisted!
hercdriver7777's Avatar
Mini-HowTo
Build a 7S2P A123 Pack With Balancing Taps
Hi all,
I recently put together a Hyperion 85" Yak 54 that I am running on 14S A123s. So far, I love the plane, the way it flies and I am really liking the batteries. Anyway, I've been getting a lot of questions about how to build the packs from local guys, and I remember when I started this project I had to search all over to find all the info I wanted so I thought I would post a little how to.
Disclaimer: I am not a battery genius or expert! There are probably better and neater ways to build a pack like this. So, if you know any of them share with us please...
Jul 09, 2007, 06:48 PM
txfly's Avatar
id try 1p with a smaller prop and see how it goes or even experiment with higher cell count with 1p if you can. i bet you could still get 8 minutes and shead a pound.
Jul 09, 2007, 07:03 PM
I am doing another 30% Yak (SD models) with a bud and we are going to try 16s 1p and see how it works out.
I am very happy with the above setup though! The batteries weigh 39 oz a piece (4.87 lbs), the motor and ESC weighs 1.8 lbs for a total of 6.67 pounds. That, in my mind, makes it a pretty even conversion for any DA50 powered/sized plane.
Jul 10, 2007, 09:29 PM
know it all
Have you done a thread on the plane itself?..
I try to use as much of the existing tabs as possible.. they can handle up to 100amps so they are good. I just made several 10s1p packs in a straight configuration, only had to use 3 bars per pack, and a mess of balancing wires
Jul 11, 2007, 10:03 AM
Not yet, but there is a thread on it in the giant plane section already. Maybe if I can get some good video this weekend I will start a thread for the A123 powered version.
Jul 11, 2007, 11:03 AM
What you want to do is get the e-Station Dual Link cable. This connects the 2 e-Station PB-6's together. This will keep both packs perfectly balanced to each other. The Cable is $4.95.
http://www.rcaccessory.com/index.asp...ROD&ProdID=198
RC Accessory, Inc.
Auth US Bantam Importer
Jul 11, 2007, 11:25 AM
RC Accessory, Inc.
Very good idea! However, one of those balancers is a pb5. I suppose I could upgrade
Dec 06, 2009, 02:10 PM
57sailplane's Avatar
good info.. thanks
later andrew K
Dec 07, 2009, 07:24 AM
Giz
Giz
Tony Rogers
Giz's Avatar
I would be very interested in that.
Discussion Building A123 packs with Balancing tab Jay_Limn Batteries and Chargers 5 Aug 11, 2007 07:54 AM
Discussion balancing a 7s a123 pack with the TP balancer kogibankole Batteries and Chargers 2 Jun 20, 2007 01:17 AM
Sold Milwaukee V28 --- e-Moli 7S1P 3000mah built pack with TP taps 4/6pin kookboy Aircraft - Electric - Batteries & Chargers (FS/W) 2 Jun 05, 2006 01:30 AM
Sold e-Moli 7S1P 3000mah built pack with TP taps 4/6pin kookboy Aircraft - Electric - Helis (FS/W) 7 Jun 05, 2006 01:29 AM
Balancing a pack with taps. An easy method? IA-Flyer Batteries and Chargers 99 Jan 21, 2005 10:35 AM
