This thread is privately moderated by Jack Crossfire, who may elect to delete unwanted replies.
Jul 08, 2007, 09:39 PM
Jack Crossfire's Avatar
2 way wireless
So the replacement MAX3389 had no effect on the PDA. With the new MAX3389 it couldn't even receieve data. Options are to buy a commercial serial port for it ($40) or get a more portable laptop ($600).
Moving forward with the old laptop, finally got 2 way wireless working. Phase shift keying, 4 bit flow control, CRC checking, and transmitter power cycling are all working.
The ground station first enters 2 way mode when the user enters an i. To flush the serial buffers, it takes a bunch of i's. Vicacopter is programmed not to enter 2 way mode unless the throttle is off and once in 2 way mode, to fix throttle at 0. Need 2 test that. Vicacopter sends a private code to exit 2 way mode. The user must exit 2 way mode before the throttle is reenabled and transmitter cycling is disabled.
Cycling the 72Mhz transmitter every 1/2 second to defeat interference works. It's super slow but usable. Only 1 packet can travel in a single cycle. The algorithm could be improved to combine multiple packets in a single cycle, but this may be replaced by a proper 2.4Ghz modem.
Have the video of 2 way wireless working for the first time.
2 way wireless (1 min 6 sec)
Vicacopter's menu system of course, is another phase.
FS: 1x Used 1x New 2.4ghz Wireless video cameras with receiver Nik-rc Aircraft - Electric - Airplanes (FS/W) 4 Nov 30, 2004 07:21 PM
FS: Draganflyer IV w/2.4Ghz wireless camera Razmo Aircraft - Electric - Helis (FS/W) 6 Aug 19, 2004 09:30 AM
Opinions of Satellite Internet (2-way) services? Steve McBride Life, The Universe, and Politics 3 Feb 12, 2004 11:42 AM
JR XP642 convert 2-way flap switch to 3-way Stelio Radios 1 Jan 21, 2003 02:38 PM
