FROG Linnet at 36" span with flying shots...
Heres a picture of my recently finished scaled up FROG Linnet, at just over twice size, with brushless electric and micro r/c, I was delighted with its first flight (at 52 minutes), its almost totally silent, and I couldn,t wish for a nicer vintage flyer, now that I'm hooked on the brushless electric / vintage combination, I think Vic Smeed's Debutante will be next. I always try to finish the aircraft in period colour schemes, and I think the dark blue and cream looks good - even though I say it myself!!!
That really is a very nice conversion sir!
What motor and battery combination have you chosen? Graham |
Hi Graham - it has an Axi Gold Line 2212/34 brushless motor and a 3 cell 1320 mAh Lipo, this combination provides a good reserve of power, and a long flight time - All I need now is some good summer evenings to fly it!!!!
The cotton closed loop system for the twin rudders and elevator are shown in these pics, I spent a lot of time during the build thinking of different ways to do the rudder control, but settled on this, both rudders are connected to a central mounted mini servo and the thread to the outside of each rudder actually passes through the fins. - Not very high tech, but simple, reliable and weightless!!!
A beauty!
Would love to see pics of wing structure... how did you change it with the enlargement? hmmm... love the Heron, but maybe as a tail dragger. So many beautiful planes, so little time! |
Hi Wingbeat,
the only changes in the scale up were structural ones, the outline of the aircraft is exactly correct, even the wing rib spacing is correct, but with LE half ribs fitted to keep the aerofoil shape. the fuselage is built up as you can see instead of the sheet used in the small Linnet. and the section of fuselage over the wing had to be removable with the wing (on the original model the wing slid into the wing slot..not feasable on this model. I attatch a wing view.(as you can see the model was going to be red and cream - but I didn'tlike it!!! sorry the wing was covered before I took any pics, the FROG Interceptor box was just used to show the size of the model.. |
Hi Wing Beat,
the wing is just a standard 3/16" x 1/2" mainspar on the botton and above it a 1/8" sq stringer, and the ribs are 1/16" sheet, it does'nt sound very strong, but the 1/8 stringer over the top of the main spar makes the wing quite rigid. Just the usual 1/16" ply dihederal braces on either side of the mainspar and LE and TE to just beond the first rib position, the centre section of course sheeted to take the fuselage fairing. The model is covered in Litespan. The dihederal was left the same as the original FROG model. |
1 Hour 16 minutes - best flight so far!!!
Last nights flying session with the Linnet, was the best flight so far (flight number3!!!) A super calm evening, hand launch at 20.18, then a mix of low flypasts, some slow, some fast, and a bit of general low level stuff, then half an hour of back - and -to as a tiny spec at about 500 feet, I then had to show its awsome climb rate to the other guys!!!this thing climbs like an F16!!!! Then, back down low for a bit more close up stuff and finally a landing at 21.34 - My longest ever flight with an r/c model - 1 HOUR 16 MINUTES
A few distant flying shots from flight number 4!!!!!!!!
Thread Tools | |
Similar Threads | |||||
Discussion | First attempt at low light (sunset) shots - UPDATE - Now with crash shots! | cadmonkey | Aerial Photography | 9 | Jun 23, 2007 02:50 PM |
Discussion | More great flying shots at Shangrila II | Pat Daily | Scale Kit/Scratch Built | 9 | Aug 23, 2005 10:29 AM |
F/S *RTF* 36" Custom Flying Triple Wing with 3 J250 motors, OH MY!! | MailOrderGuy | Aircraft - Electric - Airplanes (FS/W) | 3 | Jul 10, 2004 02:03 PM | |
Is flying at partial throttle with a sensorless brushless motor bad? | Mitch G | Power Systems | 6 | Dec 12, 2001 03:15 PM | |
Take a look at this 24 inch flying wing | Acer | Electric Plane Talk | 2 | Sep 10, 2001 02:29 PM |
