Jan 13, 2009, 05:54 PM
"I Am The Animal!" in training
helifryer's Avatar
i doubt that my rx had anything to do with the crash, since i have both ailerons into the same channel, and i still had control of the right aileron. the right one just locked down.
( i just got another electron 6! dont scare me like that!)
Jan 13, 2009, 07:04 PM
Long time newbie
If you are using a y connector the problem almost has to be the one servo that isn't working. Probably something mechanical like a broken gear tooth. I would think if it was electrical it would knock out the other servo as well while the two are connected together.
Mike K
Jan 13, 2009, 07:14 PM
3DHS 'native'
going4speed's Avatar
I ordered a couple thanks!
About how long does it take to get delivered from China?
Originally Posted by gpdno
Hobbycity
https://www.hobbycity.com/hobbycity/...trunner_1500kv
They also have the 1300kv and 1700kv...
Jan 13, 2009, 08:12 PM
helifryer's Avatar
long time
Jan 13, 2009, 08:34 PM
Lee / RC Enthusiast
YarSmythe's Avatar
My orders usually take 10-12 days. For the price, it's worth the wait.
Jan 13, 2009, 09:51 PM
3DHS 'native'
Works for me!!
Jan 14, 2009, 02:16 AM
Hole digger
DampRabbit's Avatar
If you pay for EMS shipping it gets here faster than Horizon will ship my orders.
Jan 14, 2009, 11:51 AM
DanT's Avatar
Really Dan? I have 4-5 Electron 6's. They work great for me. Only trouble I've run into is when I shorten the antenna using their wire wrap or a 3rd party mini-antenna. All of my gliders use 'em.
I've had one go funny on me but that was after it was involved in a crash. I sent it back to Hitec and they repaired it at a minimal charge. Can't really fault them in that situation.
So...that's one vote FOR and one vote AGAINST them. Anyone else want to vote?
If you read a lot about helicopters? Many have trouble when installed . I wouldn't run one.
Dan, what trouble were you having? As with all receivers, POWER is a big issue. When using a separate receiver battery (not a BEC), I've never had any glitches. Some ESC/BECs will wreak havoc on receivers.
-Lee
I fly helicopters, and if you read on many forums ,, you will come up with many who have crashed running them.
And they are talking about glitches many times.
Jan 14, 2009, 01:43 PM
Agreed! I just placed an order on Thursday 1/8 and received it at my front door on Monday 1/12 via EMS shipping. Very impressive.
Coincidentially my order included 2 of the 1500 kv 24 gram motors for another project.
Jan 14, 2009, 03:41 PM
gpdno's Avatar
I always use the EMS shipping. I can order on a Monday and have the parts on my door Thursday or Friday. It's the more expensive shipping option but I usually wait until I need a bunch of stuff so the larger order makes it worth it. Their shipping cart is nice in that it tells you how much more weight you can add to your order for a given shipping option and I make a point to max out my allowable weight
Jan 15, 2009, 10:47 PM
3DHS 'native'
Balance success!!!
I have added two inches to the nose and moved the wing back **hit enter sorry***
See below
Jan 15, 2009, 10:52 PM
3DHS 'native'
Balance success!!!
I have added two inches to the nose and moved the wing back a quarter inch.
Tack glued everything together to validate this time before building a whole plane and tada!!!
Of note is that the plans do not print out to scale. That could be part of my problem from last time. I also built it a little on the heavy side compared to the new one.
This one is built to plan scale not actual scale but I only caught this tonight so the booms are the corrected length.
Behold:
Jan 16, 2009, 10:56 AM
DanT's Avatar
Is that your battery????
It seems very big.
Tip, put your battery on the other side.
It helps to stop torque roll.
PS: I hate to see advertisement when trying to look at your pictures.
You might just use this web sites setup for loading pictures.
Jan 16, 2009, 01:01 PM
3DHS 'native'
DanT
Sorry for the picture mess. I keep forgetting to upload pics here.
Thanks for the placement tip!
It seems very big.
Jan 21, 2009, 05:24 AM
So i finaly maidend my funder today.
(a crashflight of 15 seconds don't count as a maiden )
And YES i could keep it flying (sort of) and even after the landing it was still in one piece!
Ok i admit, also bent a motorshaft, but they are soft..
It flies FASSSST, but then again the weight is 440gr or 15.5 oz.
And i guess that's a bit much
Its powered by a Towerpro 2409-12delta, 8x4 prop and a 1250mAh 3cell lipo
Maybe i should built another one, but this time light
Bye Jan Willem
Discussion Funder & Lightning SPAD Edition maybeso SPAD - Simple Plastic Airplane Designs 3 Oct 27, 2009 03:36 PM
Video Funder 'n Lightning YarSmythe Electric Plane Talk 17 Aug 27, 2007 09:38 PM
Video Funder 'N Lightning troynh Electric Plane Talk 0 Jul 16, 2007 11:55 AM
