Jul 06, 2007, 09:48 AM
what kind of paint do you use for your foamies?
some cheap spray paint from wal-mart?
have a F/L plane that will be ready to paint very soon
just a little concerned that the wood spars going to the tail of the plane will be a weak spot on not so perfect landings, may glue some carbon fiber stripes to the sides of the spars for re-enforcement
I can't leave an original design alone, have to modify some how
bert-nc
Jul 06, 2007, 09:56 AM
Lee / RC Enthusiast
YarSmythe's Avatar
some cheap spray paint from wal-mart? bert-nc
I use "cheap" Testors Spray Enamel. Hobby Lobby (crafts, not the R/C store) seems to have the lowest price. Works great. However, the cans are small so I would recommend getting at least two of your favorite color.
The plane holds up rather well on landings. I've yet to break a tail boom (knock on wood). The weakest point of this aircraft is the bottom skid. I recommend you glue on a thin plastic strip to protect the foam on belly landings. My first kit is banged up pretty good but since I installed the plastic on the Yippee! version, it has faired much better.
Spruce is strong stuff...I don't think you'll need to use carbon fiber reinforcments. However, you 'should' use a small carbon piece across the elevator to keep it straight (see top photos). Other than that, enjoy the heck out of it.
Latest blog entry: For your viewing pleasure
Jul 06, 2007, 11:00 AM
Saeed's Avatar
What is the distance from the nose to the LE?
Jul 06, 2007, 12:09 PM
Lee / RC Enthusiast
YarSmythe's Avatar
On the red F&L with the EFlite square mount and a 400XT, it is roughly 4" (LE to prop). You may need to play with this distance in order to get the CG right without having to add weight. You have room to move the battery around as well...but this works perfect for me and my TP 1320 3S pack.
Jul 06, 2007, 12:55 PM
Saeed's Avatar
Thank you for the info. Is there any drawing for the fuse? or did you just eyed it?
Saeed
Jul 06, 2007, 03:50 PM
Lee / RC Enthusiast
YarSmythe's Avatar
Thank you for the info. Is there any drawing for the fuse? or did you just eyed it? Saeed
No drawing or template...just free hand. The pics above are easy enough to cut something similar. Keep us posted on your progress!
-Lee
Jul 06, 2007, 04:25 PM
Magic Smoke Liberation League
navionflyer's Avatar
-Lee
Any chance I can talk you in to posting a profile picture of the fuselage?
Tim
Jul 06, 2007, 05:56 PM
No thrust...It'll bust...
troynh's Avatar
That would be great to have! Just cut out a quick upper and lower fuse with dimension overlays as you did in this photo.
-Tim
Jul 06, 2007, 09:25 PM
mine is ready to place electronics on
plan on using a AXI 221226 outrunner
just have to remove motor and servos from another plane that I was wanting to retire
bert-nc
Jul 06, 2007, 09:55 PM
Lee / RC Enthusiast
YarSmythe's Avatar
Originally Posted by t_j_walker
Any chance I can talk you in to posting a profile picture of the fuselage?Thanks,Tim
Here ya go.
Jul 06, 2007, 09:59 PM
Lee / RC Enthusiast
YarSmythe's Avatar
plan on using a AXI 221226 outrunner, bert-nc
Holy Frijole Batman! That's a big power plant. What prop/battery combo are you using? I want to run those numbers in Motocalc. Something tells me you're going to have EXTREME vertical performace.
-Lee
Jul 06, 2007, 10:37 PM
praymond's Avatar
Lee, did you ever try a 8060dd gws prop on your esskay? I put one on in place of a 9050, and get longer flight times, somewhat less verticle, but very enjoyable !! I can run liter batteries with it too.
man I'm enjoying your great design--- love it!!!!!!!!!!!!!!!!!
I was going to build Butch77's wild wing boomer, I have the wing blank, but now I think I'll build it with spruce spars and the same tail as the F&L. It will be easier, and stronger too I think.
Paul
Jul 06, 2007, 11:38 PM
kimhey's Avatar
Ahhh... Dialed in some Ailerondifferential, and now it feels much better! Nice goodlooking relaxing flying with my F&L. Great plane..
Kim
Jul 06, 2007, 11:45 PM
praymond's Avatar
Kim, How does act when you try to stall it? Notice the difference with the KF foil???
Jul 07, 2007, 02:05 AM
kimhey's Avatar
eh.... I know there is a difference. Do I notice it.....I am not sure really . All my depron/EPP lightweight planes have redicoulusly low stallspeed, so it is hard to tell I think. What I do notice is the better pitchcontrol, but that is probably from the thick rounded LE.
Kim
Discussion Funder & Lightning SPAD Edition maybeso SPAD - Simple Plastic Airplane Designs 3 Oct 27, 2009 03:36 PM
Video Funder 'n Lightning YarSmythe Electric Plane Talk 17 Aug 27, 2007 09:38 PM
Video Funder 'N Lightning troynh Electric Plane Talk 0 Jul 16, 2007 11:55 AM
