Jan 27, 2013, 04:55 PM
huffy1976's Avatar
Ailerons work well and are not disturbed by the new wing profile.Today was very cold, so I did not test any plane.
F & L 2 and 3 wait good weather.
20130127 230300 (0 min 27 sec)
Jan 27, 2013, 09:11 PM
Here is my first attempt. She is pretty tail heavy, so that will be fixed along with the new prop and motor mount.
I used Dollar Tree foam, and built her with a 40" wingspan. I laminated 3 pieces together for the fuselage, and 2 pieces for the verticals under the horizontal stab. AUW is 19.11 oz with a 3s 1800mah battery. I will get her all painted when I get her flying well.
Funder and Lightning, tail heavy maiden (0 min 24 sec)
Thanks to everbody on this thread for all your wisdom, and especially yarsmythejr for the original design.
Lincoln
Jan 27, 2013, 10:36 PM
KlonWarz
Huffy, Gosh! what a great photo spread!
...can't wait 'til you see some good WX!
...shorten your booms, Linc ???
what are all the details of what you are running? I'd like to know...
tnx
rc
Jan 27, 2013, 11:00 PM
Lee / RC Enthusiast
YarSmythe's Avatar
Originally Posted by Linc75
Here is my first attempt....Lincoln
Lincoln, Bummer. Let us know how the SECOND attempt (and successful) flight goes!
Jan 28, 2013, 04:46 PM
tnx
rc
I'm running a Power Up 400 slofly motor, 28mm 1.8oz 930KV. With a 9x6 APC prop/ which should be good for ~26oz thrust.
ESC- 22 amp HURC
and a 3s 1800 mah 30C DBY Battery
for servos I'm using Power Up 9g sub-micro servos
I got all that stuff from www.headsuprc.com
Hope that helps.
And I'm going to try and see if I can add 2 or less oz to the nose (between the motor stick and top fuselage) before I try shortening up the booms. But thanks for the suggestion.
Thanks for the encouragement,
Lincoln
Jan 28, 2013, 07:30 PM
KlonWarz
I have never built an F&L, Linc, but I've read a lot abt the planes... easy to add weight, and that could tell you quickly if CG is the problem, yet all accounts lead me to believe the model will fly better if lighter. I guess you could shave the booms on the sides???
and 'they' have said it's ez to bend those long motor prop shafts in a tractor config...
Best
rc
Jan 28, 2013, 09:18 PM
10-4 on both points Rusty. My first was a fail but the next will be lighter.
Jan 28, 2013, 10:58 PM
KlonWarz
Tnx Raften! :-)
Well, as an armchair commando, I've had opportunity to read up on many problems others have encountered, and some of what they learned has sunk in...
SO, when I am able to get components and build my first airship, it will fly like a demon escaping the gates of hades, right? lol
Yah, right... lol
I did built up wings years ago, and it's a real setback to see 'em impact something.
Sometimes, the 'foamie bounce' is even entertaining!
Best
rc
Jan 28, 2013, 11:30 PM
Another lovely day with my F&L
Funder&Lightning R/C Plane (10 min 41 sec)
Jan 29, 2013, 08:13 AM
Lee / RC Enthusiast
YarSmythe's Avatar
3998, 3999.....
I have nothing to add to the F&L thread. Just excited to see we hit
4000 POSTS!!!
Cool. Thanks fellas!
-Lee / YarSmytheJr
Jan 29, 2013, 10:28 AM
huffy1976's Avatar
Funder & Lightning 3 - 120 cm(47.2 in) maiden flight
Looks like 4001 is the lucky number for me .Today was a lucky day for F & L 3.
Maiden flight was a success.He flies like a dream and he have very good gliding capabilities.Thanks again for the plans.
I do not understand why smaller version 25 " not fly properly.I have to build another one and see what happens.
Funder & Lightning 3 - 120 cm(47.2 in) maiden flight (6 min 19 sec)
47.2" with all electronics + battery 2S 2200 = 29.55 oz
About 6 minutes of flight time consuming 1183 of 2200.
Next time I will try with a 2650 3S battery and 9x5 propeller.
Jan 29, 2013, 12:34 PM
KlonWarz
Wow!
It looks COLD in Sibiu, Huffy!
ALL these vids are encouragement for me to make bigger profile, paint in contrast colors to background, and seek video advice to avoid .dot in sky. movies...
rc
Jan 29, 2013, 12:50 PM
huffy1976's Avatar
The shootings was done by me while flying the plane.It's hard enough to find someone to shoot on that cold ... -4 * C.Next on the list F & L 2.4m = 94.5 "
Jan 29, 2013, 01:34 PM
KlonWarz
Very good to fly & film at the same time!
rc
Jan 29, 2013, 04:13 PM
[QUOTE=huffy1976;23967716]Looks like 4001 is the lucky number for me .Today was a lucky day for F & L 3.
I also find out bigger versions are more stable than there smaller ones, not only for F&L, for most of the other planes I build.
Discussion Funder & Lightning SPAD Edition maybeso SPAD - Simple Plastic Airplane Designs 3 Oct 27, 2009 03:36 PM
Video Funder 'n Lightning YarSmythe Electric Plane Talk 17 Aug 27, 2007 09:38 PM
Video Funder 'N Lightning troynh Electric Plane Talk 0 Jul 16, 2007 11:55 AM
