Jan 09, 2011, 02:17 AM
Plane Crazy
cincy's Avatar
just finished mine, man am I tired. painted all red, red and white striped bottom wing. Some detail work to do still but am going to head out in 5 or 6 hours and maiden it at the local school yard. Was my first scratchbuild and it was a lot of fun. Used electronics I had laying around. Will report out how the maiden went later tomorrow. Thanks for all of the great information in this thread. Even if she goes down in flames, it was a fun experience starting with nothing but parts and foam sheets and producing a plane.
Jan 09, 2011, 11:49 AM
Plane Crazy
cincy's Avatar
Maiden went well despite teh 15 degree temps. I'll need to add adjust the control horns a bit to increase throws on the aileron and probably try my BP 2212-10 motor instead of the 400XT that is in there now. Could use more power. I suspect cold weather also impacted power I was getting from my battery (1300 mah 25C 3S). Nowthat I know it flies, I'll finish up painting a canopy and some odds and ends. That may have to wait, if I keep ignoring the family to work on my plane, I'll be sorry!
Jan 09, 2011, 02:09 PM
Unrepentant Carnivore
jamesdr's Avatar
Conrats and welcome to the F&L club!
Jim
Jan 09, 2011, 04:53 PM
Airplane and Heli Flyer
V-Man's Avatar
Getting packed for moving next week, so I cleaned out the workshop. If you remember, I had a bad crash with my pusher F&L ("Orbiter") a few weeks back. So regretfully, I striped it of all equipment, and junked a good half of the airframe (the smashed fuselage, vertical tails, elevator).
I'm keeping the wing and tail booms for a possible rebuild once we're at our new place. The wing will need some serious work -- I'll probably trim the tips as they are pretty ripped up. WS will drop from 42" to 40", still plenty to carry it along. Tape will take care of the dings on the leading edge. I might convert it to a standard tractor, as I had serious problems hand-launching it with enough force without risking my fingers! (Ideas welcome...)
As for my second F&L, it's going on the backburner again, unless I can secure some work space and a place to spray paint (we're going to be living in a condo in downtown Toronto -- no workshop for the next twelve months ). Too bad -- I got a nice three-blade prop for it, looking forward to trying it out!
Jan 09, 2011, 06:56 PM
QuAd FaNaTiC
Razors edge 29's Avatar
My UM F&L is on hold because my green dot vapor brick is having servo issues; so I am swapping in an AR6400 with AP05 BL motor; which may mean i'll have to redesign a few things up front.
Stay tuned
Jan 12, 2011, 12:01 AM
gatorlynch's Avatar
Flight Videos- onboard camera
Here are some onboard flight videos of my SPAD F&L made from Corroplast.
I do believe I've finally gotten the CG dialed in. She's heavy, but flies well.
Thanks for a great design !!!
Budd Cam - Funder & Lightning (2 min 3 sec)
RC IFR into fog - onboard camera (2 min 16 sec)
Jan 15, 2011, 08:41 PM
Plane Crazy
cincy's Avatar
Pics of my F&L
Made from cellfoam88, BP motor and Eflite 18 amp esc, GWS HD8X6 prop. Trying to figure out how to get the word FUNDER in big yellow letters on the top of the wing. Could hand paint it but that would not look so good, printing the letters on white decal paper may work. Should be able to fly it tomorrow (I hope)!
Jan 15, 2011, 11:03 PM
Lee / RC Enthusiast
YarSmythe's Avatar
Cincy...
Kinda looks like the one sitting behind me!
Looks great. Keep us posted on the maiden. Have FUN!!
-Lee
Jan 15, 2011, 11:26 PM
Plane Crazy
cincy's Avatar
Yeah, when I'm not working with military type planes, I tend to paint my planes red. Brightened up the booms with yellow acrylic. Attached a pic of the bottom side too. Will figure out how to add the word FUNDER in yellow across the topside of the wing. I have already flown it using a 400XT motor and different prop. I suspect this set up will be a good deal faster.
Thanks for the design and all of the info.
Jan 16, 2011, 12:06 PM
Lee / RC Enthusiast
YarSmythe's Avatar
New Fuselage template
I'm playing with a new design fellas. Don't get me wrong, I'm quite happy with the flight characteristics of the current design...but I've always wanted to push the nose forward a bit like the real "Lightning".
Nothing extreme. The nose has been pushed up by 1.25" while the canopy has moved by 2.5". The belly has more area up front too.
I'll give this a try on the one I'm building for dog fighting and let you know how she flies.
-Lee
Jan 16, 2011, 01:52 PM
beemerdon
beemerdon's Avatar
Cincy, I think I got a big sheet of letters and numbers from Michael's hobby shop here in town. Just peel off the letters and then maybe put some WBPU over them to hold them in place.
Don
Jan 16, 2011, 04:58 PM
Plane Crazy
cincy's Avatar
thx
Don
Great, thanks for the tip. I'll check it out
Jan 16, 2011, 08:25 PM
3DHS 'native'
going4speed's Avatar
Lee,
I have always added 1 1/2" to my funders since the first one.
Look forward to seeing this built out!!
-Lee
Jan 17, 2011, 01:57 PM
Lee / RC Enthusiast
YarSmythe's Avatar
build build build...
Coming together nicely. May have it completed before Friday. Now...what color to paint it??
Jan 17, 2011, 11:52 PM
Completed FL - 40" ws
Well, I've done it. I built a 40" FL. My first.
I did a bottom wrap KF wing, 6 layers of foam on the bottom side to store the 1300 lipo "inside", 2 layers on top. CF wing spar. Spruce square tail booms. 9g TP servos.
My AUW is 18 ounces with a TP2409-12. Power will not be an issue, but this is no light weight.
Not very "pretty" now that it's done.
Lousy weather here in the NW now, but hope to do a maiden soon. Will report then.
Thanks to all that have posted and provided thoughts on this project. Quite a change in styles from my Zagi wings and P51 type planes. A bit concerned about landing but the prop saver will hopefully "save" the prop and plane.
Blade
Discussion Funder & Lightning SPAD Edition maybeso SPAD - Simple Plastic Airplane Designs 3 Oct 27, 2009 03:36 PM
Video Funder 'n Lightning YarSmythe Electric Plane Talk 17 Aug 27, 2007 09:38 PM
Video Funder 'N Lightning troynh Electric Plane Talk 0 Jul 16, 2007 11:55 AM
