Busted - are you landing on grass or runway? My experience - grass will break a prop at least 50% of the time unless you do one of those "tail drag and flop" landings. Landing on a runway and I'm at like 95% success rate. Personally - never really like the prop saver on a high performance motor. Sometimes windmilling the prop helps keep it from getting stuck in the verticle position. Have you turned the break off on the ESC?
Jim |
![]() Since switching to the GWS HD props, I've had no problems at all. In fact, I've gone away from wobbly prop adapters and use the regular ones now. Take a look at my last video. That's how I land with every flight and have had no problems. In all of my flights (and I have more than 100), I've experienced only ONE prop break. Not trying to brag...but dat be da truth! As for the 10" prop, I agree that it is too long. Try to get it down to an 8" or 9" prop. -Lee |
Latest blog entry: For your viewing pleasure
I am a newcomer to rc flying having only 8 flights with my 20" nutball but I really want to have a go with this design.I like to build straight forward no nonsense foamies and the Funder falls into that perfectly.I haven,t read through all of the posts but enough to want to make a start.I am getting better with the nutball and now want an aileron plane.This one seems to fly so nice with both slow and fast capabilities that I feel confident to give it a go.
I want to use EPP in the build as I am not keen on using depron(breaks too easy)so may have to add a bit more carbon strenthening to keep thing rigid.As a novice I still crash(not so much now)so I am thinking of maybe a folding prop to help minimize breakages. Has anyone made this as a pusher as the design seems ideal for it in that set-up. Just put together a 22" nutball and plan to play with this until the Funder is ready. Thanks for a nice style of foamy ,makes a change from what I have been building and trying to fly. John |
Jim |
Do you think this plane is too fast for someone like me with limited flying time. John |
John
The beauty of the F&L is that it can be flown fast or slow. Lee's video shows it best. With a larger, low pitch prop and a lower kv motor, she floats along - very neutral and an honest flyer. I've gone through more than my share because I over power them and push them beyond my skill - but I am getting better! ![]() Jim |
Hebert (sounds like [A-BEAR] for you non-cajuns) |
Hey jon.
This was my first scratch build, second plane, and first ailerons plane. Since then v built about a dozen planes. Half are in pieces now, and the rest don't fly near as good or fast, or are as durable. My funder is my favorite plane, and still flies best. Go for it! And props to lee for an amazing design! Helifryer |
One suggestion I might recommend to new builders is to consider a motor that spins a larger prop and add gear. If you can spec it to fly a 10" or 11" prop with only 4-5" of pitch it'll run nice and slow. The gear will not only help you keep the prop from hitting the ground but also lower the CG so it will want to stay upright. Just a thought anyway. On the other hand...it flies super sweet the way it is. ![]() Go for it. It's a super cheap and easy build. You can't go wrong. -Lee |
Also I build with EPP so may have to use more carbon to support it and stop it being too flexy.My motor weighs 19grams but may get a 24gram motor if needed. My flying so far is 8 flights with a 20" nutball and about the same with a rc converted FIK 80.No low wing experience as of yet,but your plane seems more mid-wing than low-wing so maybe I stand a chance of giving it a go. Thanks John |
The plane is aileron/elevator. Not too hard to fly but rolls are quick. When making turns you have to roll the plane into a bank and use elevator to keep it in the turn. If you have it flying fast...it can get kinda scary (and blurry!). What have you got to lose?? ![]() -Lee |
Thread Tools | |
Similar Threads | |||||
Discussion | Funder & Lightning SPAD Edition | maybeso | SPAD - Simple Plastic Airplane Designs | 3 | Oct 27, 2009 03:36 PM |
Video | Funder 'n Lightning | YarSmythe | Electric Plane Talk | 17 | Aug 27, 2007 09:38 PM |
Video | Funder 'N Lightning | troynh | Electric Plane Talk | 0 | Jul 16, 2007 11:55 AM |
