This thread is privately moderated by leadfeather, who may elect to delete unwanted replies.
Apr 24, 2020, 03:52 PM
Gorilla Glue
Has anyone tried this on EPP or depron.
Apr 24, 2020, 06:34 PM
tspeer's Avatar
Not tried it on EPP. It's a standard adhesive for styrene foams like Depron. I prefer the white version, though. It doesn't foam as much.
Apr 25, 2020, 11:15 AM
Lead On, O King
spectra's Avatar
Yes it works quite well but you have to manage the foaming with compression or trim off excess when fully cured.
Apr 25, 2020, 10:10 PM
rab
rab
Muddle on
rab's Avatar
I am not fond of it for most uses on EPP because it dries rigid. I use gorrilla on depron and the like, but managing the foaming can be a challenge.
Apr 26, 2020, 07:50 AM
crash&fix612's Avatar
I love white gorillea glue. Just remeber the #1 rule: If you think you applied enough glue to the joint... You used too much
Apr 26, 2020, 10:37 AM
tspeer's Avatar
Packing tape over the joint helps to control the foaming. It's easily removed after the glue sets.
Apr 26, 2020, 11:09 AM
ForeverFlying's Avatar
https://www.mohrcomposites.com/
Great source!
Apr 27, 2020, 06:33 AM
Kit Manufacturer
coreman's Avatar
Or blue painters tape for easier removal after. For EPP I prefer Foam-Tac or similar to maintain flexibility
Latest blog entry: Release of our 40" EPP Yak55 XL
Apr 28, 2020, 03:37 PM
hi, is there any place i could buy a small piece (about 12"x12") of EPP foam for small repairs.
every place i see sells giant pieces for scratch builders. thanks..
Apr 29, 2020, 05:36 PM
EPP Seller and Kit Manufacture
iCrash2's Avatar
Nitro Burner, I can supply you with smaller sheets of EPP.
I can custom cut thickness and length and width in #1.3 and #1.9 EPP in white and black and I have a limited supply of black #2.8 right now.
Thicknesses of 3mm - 1" are cut on my slicing machine and anything over 1" is cut with my hot wire CNC (hot wire leaves a thin skin on the surface).
Send me a private message and we can work out the details.
Apr 30, 2020, 05:36 PM
hi, thank you sir. i will figure out what it needed and send PM.thanks again...
The Great 'Links to Free Plans' Thread! tim hooper Foamies (Kits) 194 Jun 08, 2011 12:59 AM
Yippee! Helicopter building tips and tricks - class 101 Happymcc Micro Helis 25 Oct 29, 2008 12:40 AM
Yippee! Please post your links to free plans HERE! CactusJackSlade 3D Flying 12 Oct 08, 2004 01:30 PM
The Great 'Links to Free Plans' Thread! (split by moderator) Zachary Foamies (Kits) 6 Oct 01, 2004 09:46 AM
EPP Building Tips Wanted jolive Foamies (Kits) 6 Jun 12, 2002 05:56 AM
