Jun 15, 2007, 09:59 PM
bdp3822's Avatar
Aileron Servo(s): One or Two???
Newbie was just wondering if building a pylon ship with two servos is worth the trouble...
Will the Spoileron/Flaperon functions really slow a pylon plane that noticebly?
All comments welcome!
Jun 15, 2007, 10:56 PM
Caution:Makes sharp left turns
Troy's Avatar
Generally two servos are run for 'snap flap' to mix some camber in the turns. The secondary function of two servos is to run spoilers to shorten landings. To be honest, if you are not at a high wing loading then two servos are sort of over-kill. One servo is usually plenty sufficient. Sometimes running two servos can simplify the linkages and adjusting the throws/centers. If you have the room and an extra servo, two aileron servos are nice... but they are not necessary.
Jun 16, 2007, 01:44 AM
bdp3822's Avatar
Thanks for the info!
I have never used ball linkages before and the Flash Pylon I got comes with unthreaded aileron linkages/ball joints.
Do I have to thread the linkage and use a nut over the ball joint or do I just secure the ball end with some CA?
I know I know what a noob right? hehe
Jun 16, 2007, 04:19 AM
f5b-uk
Mike Seale's Avatar
I'd solder the ball on.
Jun 16, 2007, 02:12 PM
bdp3822's Avatar
Thanks for the tips guys!
Hopefully get this thing finished soon!
Wanted Looking for one or two spaceboxes for P-4000's nmchappy Aircraft - General - Radio Equipment (FS/W) 0 Apr 20, 2006 11:28 AM
One or two set screws for motor mount? Jim13704 Power Systems 0 Jul 21, 2004 12:51 PM
FS: One or two Hitec Feather receivers, channels 30,46 jgmtens Aircraft - Electric - Airplanes (FS/W) 6 Jun 11, 2003 10:19 PM
20 cells, one or two packs? Bill Mixon Batteries and Chargers 8 May 30, 2003 08:21 PM
New to the Forum ... one or two questions Tailhook2k Electric Heli Talk 5 Dec 14, 2001 01:44 PM
