Jun 15, 2007, 11:45 AM
I love FPV!
Cralis's Avatar
DX7 Binding
Just got my DX7 with AR7000.
But I am unable to bind them. I plug the bind plug onto the charge lead. I use the male bind plug. The female does nothing. Just dangles.
I pluf the power pack into the RX power socket.
Switch on the RX pack, and the RX flashes once very quickly, and that's it. It's supposed to flash forever saying it's in bind mode. But nothing. One VERY quick flash, and that's it.
I have nothig else plugged into the RX. Just the power.
What am I doing wrong?
Jun 15, 2007, 03:20 PM
I would remove the switch harness and see if you can bind the rx directly.
Jun 15, 2007, 06:28 PM
first -read the instructions
Jun 15, 2007, 11:14 PM
Flys with Thumbs
Danal Estes's Avatar
Your statement "I plug the power pack into the RX power socket"... ??
The bind plug MUST be in the battery port on the RX. It can be plugged in directly, in which case power can be plugged into any other port. It can be plugged in via the switch harness, in which case power can be supplied via the harness. That's why there's two bind plugs... either way, the bind plug MUST, absolutely must, be in the BATT port.
That will get you the flashing light.
Help! dx7 binding problem fadetoblack Radios 13 Dec 04, 2007 10:47 PM
Discussion DX7 Binding/Battery Question Valid8r Radios 5 Jul 08, 2007 01:19 AM
