Why is this 6 oz plane so good in high wind
Ive always thought that there is no substitute for weight when the wind gets up. After years of slope soaring I have always thought that in a blow bigger heavier models handle the conditions better, and are easier to fly.
I recently got quite a surprise. I have built a 29 1/2" span Extra 300 from 3mm Depron, and its simply the best high wind electric model Ive ever flown and I am wondering why. It weighs a measly 6.9ozs ready to go complete with. High End Technologies Micro 3/3D - 70Watts max @ 7.4v 8x4 prop Castle Creations phoenix10 15C 640mah 7.4v 2S1P LiPo 3 off 3.7gm servos GWS 4 ch Rx (because it was the lightest I had) light weight wheels and 2mm wire undercarriage Wing area 214 sq ins 1.48 sq ft Wing loading 4.7 ozs/ft2 Power 171 W/lb The 10% symetrical wing is made by folding 3mm depron over a balsa spar I have it setup for 3D style surface trhrows, using the Futaba dual throw button, but I have now taken to flying all the time with the larger surface movements. It penetrates like crazy with lots of control. Inverted needs no elevator trim change. It hovers using less than ˝ throttle. Aerobatic capable using very little throttle, with unlimited vertical when the throttle is fully open. When the wind is up this is the one I power up, with so little weight, and with the low wing loading this seems all wrong - has anyone any thoughts ? Richard |
Clean means alot in the wind ... less DRAG , more wind penetration ...Nice plane !!!
Latest blog entry: Lost plans
Light weight aerobat
My interest was really picqued because I have made a 67% bigger 1250mm (49 1/4" ) span Edge 300. The fuslage is 6mm Depron, the wing symetrical rolled 3mm depron with carbon tube and depron spars.
It weighs 5 times more 30 oz Has much greater wing area 517 sq ins 3.6sq ft Double the wing loading 8.3 oz/sqft It is fitted with a more powerful Emax motor from 4000mah 20C 11.1v LiPo 26A max giving 275W 148W/lb The bigger one was MUCH MUCH harder to fly in the same wind conditions. It required much more throttle to overcome the wind and turbulance Gusts had a dramatically larger effect, much of the time I was recovering from the effects of gusts and turbulence. Its mass made it a little better with aerobatics, but it just wasnt so much fun I guess a dead stick might have taught me a lesson or two, the lighter one would I suspect have just disappeared. Richard |
Flying straight into the wind I can see how your larger model seems to have a significantly fatter fuselage which will definitely make a difference in penetration. I also noticed that your rudder seems significantly smaller in comparison to your smaller model. Either way, wind penetration is hugely important. I can fly delta wings that are low profiles in very high winds and as long as I keep the throws down the fact that they have very low wing loading doesn't seem to affect it too much. Almost the opposite is true on my scale-ish cub which has more power than my deltas.
Salter |
Larger planes simply force their way through the wind. But most smaller planes don't have that punch needed to fight the wind properly, but your plane is shaped so aerodynamically that instead of forcing it's way through the wind, it simply slides through or cuts through the wind. It's pretty much the same thing as using a saw verses a razor blade when cutting paper. The saw can cut paper, but only by force. The razor however is so sharp and slim, it can cut the same paper but with much less force.
small vs large
Putting on my control engineering hat of course I realise that the small Edge has little mass, and the control surfaces need to generate very low forces to make flying corrections.
Its friontal area is of course significantly smaller, although the fin and rudder remain true to scale on both so the larger one is proportionate. Linear dimesnions were increased 1250mm span to 750mm span, a factor of 1.67. The areas are of course 1.67 squared = 2.78 so the frontal area is almost trebled. In high winds the small one needs very small amounts of throttle to penetrate, it also has a 10% thick wing. I guess all these factors add up, to make the smaller one a lot more fun to fly in extreme conditions. Richard |
Went out again last weekend and it was gusty and turbulent. The 30A esc on the 1250 span version gave up after a few minutes flying, it was down wind of me but had good altitude - a little down trim brought it home without any real drama - good penetration
I didnt have a spare 30A with me so flew the 750 span 6 oz version but loaded it up with an 850mah 2Cell rather than the usual 600. Just out of interest I put it at the same position as the larger model when the ESC failed. I throttled right back to bring it home dead stick like the larger one, no way it was simply blown down wind further and required the addition of power to penetrate. So I conclude that the smaller, light, easily manoevered, reasonably earodynamic smaller one relies on the high power/weight ratio to overcome the wind's effects. Richard |
Rigid wing.
light weight planes in wind
Now heres a thought took a new light weight design out for its maiden flight tonight. Similar spec to the small Extra
1/10 Scale Mudry CAP 21 Span 808mm - 31.8" 175.2 sq ins AUW 9.7 ozs Wing loading 8 oz/sqft High End Technologies Micro 3/3D motor 75W from 2Cell 121W/lb Thrust 640 gm It was a really difficult plane to fly in the breeze. As the wind died down it became easier. The wing root chord is smaller, the tip chord is shorter, and the wing loading is higher - so it should go faster and handle wind better Its bult ok no dropping of wings but a beast to keep flying well. Richard |
Thread Tools | |
Similar Threads | |||||
Discussion | MicroRacers flying in high wind - try it! | Plantraco | Scratchbuilt Indoor and Micro Models | 7 | Aug 22, 2006 04:03 AM |
Discussion | Crash! Gentle Lady not so gentle in 10mph wind | arukum17 | Sailplane Talk | 26 | Jul 23, 2006 11:01 PM |
Why EasyStar is so good in wind? | rkhoo | Beginner Training Area (Aircraft-Electric) | 11 | Aug 22, 2005 05:32 PM | |
what after a slowstick? next plane good in light wind | richphoto | Parkflyers | 15 | May 08, 2003 12:14 AM |
