Mar 09, 2008, 10:13 PM
In Rc for a LONG TIME FFAA#1
laserman's Avatar
well the storm finished here in ottawa and we got snow banks over 12 - 15 feet high!!! and being snowed in i have been able to do some work on my BB and will be working on the wing
Mar 09, 2008, 10:16 PM
For the 42 inch BB what size control horn should I use?
Mar 09, 2008, 10:18 PM
Xanadu's Avatar
Okay, ya'll been yapping so much about this Blubaby, I started to build my own today.
Building it same as original.
How you figure she will be with a GWS350 and a ni-mh battery?
Finally figured out the right way to peel the FFF without it shredding.
I remember lots saying to pull it up and away, but it always kept tearing into strips when I did it.
Now I lift it up at the edge closest to me, then while pulling it towards myself, lift it up at a 45* angle, while sliding my free hand forward between the film and the foam. Comes off in one nice piece now.
Mar 09, 2008, 10:23 PM
Foam does it all
Low&Slow's Avatar
But I am thinking to get the landing gear a little more solid I might want to get some thin plywood material at the LHS and gorilla glue a small plate to the bottom of my fuse and screw the landing gear to that. Is that a good idea? Is that standard? Has someone done some inventive landing gear of this type?[/QUOTE]
Give this a try, I did it on my "SSC" so I could change from LG to floats.
Phil
Mar 09, 2008, 10:30 PM
Foam does it all
Low&Slow's Avatar
Originally Posted by Tony65x55
Use them both, either will work with a simple change of prop. The 2s lightly propped to get your BB wrung out and when your ready, the 3s will really make it burn. Are you using the KFm wing or the UC wing?
Tony
Tony, I will be using the UC for now but I have read so much about the KFm I can't resist trying one as time permits. I just can't wait till the Ohio winter is a memory and I can fly some of what I am building.
Phil
Mar 09, 2008, 10:38 PM
"On the Wing"
paulo810's Avatar
I'v been flying mine with a GWS300 A gearbox and an 8.4V 300mah NIMH battery, GWS 8043 slow flyer prop for 6 months. Slow, fast, loops, vertical, tail slides, inverted......
I get about 16 minutes flight time if just cruising.
Do it!
Mar 10, 2008, 12:35 AM
hqmq's Avatar
Phil
Awesome! You inspired me. While looking at your setup I realized that it almost looked like you could connect the ruler to the fuselage with rubber bands.... then it made me think how even with a bit of a rough landing today there was no damage, because it was the link between landing gear and fuselage that broke.... so if I leave that connection as the weak link, then I probably will not get damage to either the landing gear or fuselage, because the connection will break first!
So I did something very similiar to your setup (I didn't have a ruler, but I had a piece of plastic that was very strong and about the right size and had some convenient tabs to wrap the rubber bands around. So here it is:
Mar 10, 2008, 12:46 AM
No typos?
Do it!
OK, so I presume you INTENDED to say GWS 300 in response to HIS comment on a GWS 350?
What is your wingspan and AUW?
This is good news; I love it.
LarryR : )
Mar 10, 2008, 05:10 AM
Ken's CAD Models
dz1sfb's Avatar
I flew my first 33" BB on a GWS 350D setup with a Fiegao (not sure thats spelled right) 4225 Kv inrunner. Left it underpropped with 9x4.7 SF. Lots of potential.
Ken
Mar 10, 2008, 08:57 AM
Foam does it all
Low&Slow's Avatar
So I did something very similiar to your setup (I didn't have a ruler, but I had a piece of plastic that was very strong and about the right size and had some convenient tabs to wrap the rubber bands around. So here it is:[/QUOTE]
Just to clear up a point, that setup is not mine, I copied it from the "SSC" thread.
Phil
Mar 10, 2008, 12:36 PM
Can't see it
Phil[/QUOTE]
Did you intend to show a photo, or paragraph, or.............. ???
Sounds like something good; hope to see it.
LarryR : )
Mar 10, 2008, 12:41 PM
I'm not flying backwards!
Tony65x55's Avatar
Xanadu, welcome to the thread. A 350 will easily fly the Blu-Baby. My kid flies his 42" BB on a 350 and it has enough power for a trainer.
Tony
Mar 10, 2008, 12:43 PM
Tony65x55's Avatar
Phil
LarryR : )[/QUOTE]
I don't know why you guys just don't use the LG as designed. It's light, strong and doesn't tear out. Changing over to floats and skis involves removing two wheel collars.
Tony
Mar 10, 2008, 01:23 PM
The Dude Abides
Beemus's Avatar
LarryR : )
Tony[/QUOTE]
Agreed.
I have built several with interchangeable wheels/floats and all I do is remove two wheel collars. The floats have their own rear support gear that I rubber band to the bottom of the fuse with a few dowels glued into the appropriate places.
Oh No! Catastrophic Diaper Failure!
Gotta go......Beemus
Mar 10, 2008, 01:35 PM
LarryR : )
Tony[/QUOTE]
HEY ! I represent that. My first BB was the suitcase model that the gear had to be removeable. Bent a piece of plywood to curve of fuse. and put blind nuts on before glueing on. Liked it so well that # 2 was about the same. # 3 Is removeable also using drink cup in slot as per someone else. You won't beleive it but # 4 will be glued in. But not in stock location. HA ! I moved forward 1/2" and slight angle to help the CG thing with 39 gram motor. But youall should know by now I can't build like everybody else. Thats whats so great about Tony's BB. You can screw it up royaly and its still a fine little plane. Cheers
Ken
Video Blu-Baby Primary Trainer Tony65x55 Electric Plane Talk 0 May 05, 2007 06:05 AM
Chosing Trainer...Kit?Plans?RTF? Seared Ice Fuel Plane Talk 49 Aug 16, 2004 11:50 AM
Which SPAD Trainer to build?? Plans? VBSuperMaxx SPAD - Simple Plastic Airplane Designs 12 May 05, 2004 09:19 PM
Sold FS: Fireball 550 Trainer "PLANS" Rudderman98 Aircraft - Electric - Airplanes (FS/W) 4 Dec 05, 2002 08:38 PM
